Hey guys,
i've performed a search and found some topics covering the A-LSD,
however my question is a little different to the information provided so far, so i'm
hoping one you resident GT-R experts can help me out.
I recently imported a series 3 BCNR33 V-spec.
The car has an Impul ECU that came with it from Japan,
and a Nismo 320 cluster I installed.
Normally when I turn the ignition on, the A-LSD light
will illuminate for the standard cluster warning light fault check.... as soon
as you start the engine, the A-LSD light goes off.
The scenario:
Since i've had the car on the road, I have not seen the A-LSD light
come on once whilst driving.
The other day (my first time in the wet with the car) - I did a wide open
throttle launch from first gear and into second on a very wet road.
The front torque meter pretty much went maximum on the launch and all
through first gear.
After backing off midway through second gear and slowing down, I noticed
(for the first time ever) the A-LSD light was on - and it wasnt going off.
I drove for about 4 minutes more back home, then turned the car off.
Started it again about 20 minutes later and went for another drive, the A-LSD light
was now off.
I havnt seen the light come on since, except for when you start the car.
Now my questions:
1) is the A-LSD light a "fault" light or is it supposed to illuminate when the specific computer
controlling it has commanded it to come on?
2) do I have some form of error (with the Active LSD itself) since the light came on solid and remained on even with sedate driving afterwoods?
3) Is it just something to do with the fact its running the Impul ECU and its getting that error
mentioned in Paulr33's A-LSD DIY guide (http://www.skylinesaustralia.com/forums/in...howtopic=107656
any advice or help much appreciated :happy:
https://www.sau.com.au/forums/topic/128328-vspec-a-lsd-info/
thanks govich - now i've re-read his thread and
you guys rekon the A-LSD light coming on means its
failed or turned off - makes a bit more sense.
I've had some confusion with this as other GT-R owners
have told me that when the light comes on it means its working!
The "clean" dashboard normally means everything is working, its
only when a light comes on something is wrong.
Kind of like stories some people tell that when the Hicas light comes
on it means its working :cheers:
The reset obviously did the trick.
I'm still left wondering if I have a problem with the Active LSD
itself or its this aftermarket ECU issue.
I'm tending to think there is something up with the ECU as the rest
of the car is flawless.
Edited by rb4door
I was told that if you continue to slip the wheels for 20secs or longer the computer goes into safe mode and it becomes an open wheeler does anyone know if this is true or not? And yeah as everyone has stated the ALSD light only goes on when there is a problem.
Chris
^^ would seem to tie in with what I experienced.
However I would have thought a GT-R is a little bit
tougher than to chuck a dummy spit at one decent launch with
some possible wheelspin in the wet.
I still think there must be an error with my ecu or the A-LSD itself
Interesting... I have a fairly modded 33vspec and have done numerous heavy launces with alot of wheel spin and even done doughnuts in fwd, and never had ATTESA or ALSD lights on, other than at start up.
So I would say these lights only come on when there is fault, like the rest of the fault lights on the dash.
correct the a-lsd light will on come on when it fails.
failure can be electronic signal problem from the ecu (it needs tps signal) or it can be its locking for too long and gives up. if you lock it for say 25 seconds it usually gives up and a-lsd fails
Finally found my GT-R manual....
A-LSD Warning Light:
If the light comes on with the engine running
it may indicate that there is something wrong
with the active limited slip differential system.
Have the system checked by your Skyline GT-R dealer.
If an abnormality occurs in the system,
the A-LSD function will cease and the differential
will operate conventionally.
I dont like the way its worded - still very open to interpretation
"may indicate there is something wrong"..... :O
yes as i said. if a-lsd comes on while driving it means the computer in the boot has detected an error and gives up. this means the system will not lock the diff when traction is lost. slip will NOT come on if a-lsd is light up. you need to reboot the car to correct it.
common causes for a-lsd coming on that i have seen:
running the pump manually (computer doesnt expect it to run)
doing a long burnout (over 30 seconds, a-lsd will fail)
tps signal to a-lsd computer not clear or disconnected
just read it all - thanks for the link....
The FAST schematic you have put up
looks exactly like the pump on the back on my diff housing -
so that part is the pump that runs A-LSD?
I have always been told the hydraulic fluid reservoir in the back
right access panel in the boot is the reservoir for the ATTESA 4wd
system on GT-R's - so i'm not sure if this is a shared reservoir on mine
and only for A-LSD on your GTS-T?
I can also hear an electric pump at the back upon startup of my car,
seems to run for about 4 or 5 seconds then turn off - like its
pressurizing. Do you think this would be the ATTESA system or the A-LSD?
Edited by rb4door
the resivour in the boot right hand side is the a-lsd fluid.
when i turn my pump on via the hardwired switch we can see the fluid level drop instantly. its definetly a-lsd fluid resivour. the diagram is from nissan fast which shows the a-lsd pumps, resivour and return systems. it attaches to the diff via an oil feed (in the diagram). the diff has the vspec finned cover despite being in a gtst skyline.
i have ecr33 gtst skyline with a-lsd option fitted. what car do you have?
the a-lsd in fast is listed as the torque split system.
nevermind just read you have series 3 gtr33. my bad.
yeah so gtst with vspec diff and a-lsd have that same resivour in the boot right side
hmmm, I wonder if its a shared reservoir in mine (ie for both ATTESA & A-LSD)
If you leave yours in automatic mode (computer control)
do you also hear a pump running when you immediately
start the engine?
I'll have to get a friend to start my car while I am listening underneath
at the back - see if I can work out if its the ATTESA pump or the A-LSD.
Edited by rb4door
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
