just a few questions on these adjustable cam gears
a) whats a good price for them
B) should you use buy both inlet and exhaust?
c) do they confuse any ECU's?
d) whats involved in setting them up and tuning them?
e) under what situation are they recommended ie for a heavily tuned vehicle, to reduce lag, increase tuneability??
thanks
adam
Adam,
They cause the cam overlap to change, meaning the cylinder fill is different.
Most R33's use the exhaust cam gear only, as the inlet gear removes the variable cam timing, but I don't think RB20's have NVCS.
Easy to install, rev210 did his in under 1 hour.
See'ya:burnout:
Usually about 5kW per cam gear on stock cams, more if you have aftermarket cams.
If can reduce lag, but most people use it for top-end power, which reduces power down low.
You can dial in the gears for top-end power or mid-range torque.
See'ya:burnout:
Hi adam 32, by changing the overlap/separation on the inlet and exhaust camshafts you can most definitely improve the responsiveness of the engine.
However it is a lot easier to set them up for maximum horsepower, we simply run the car up on the dyno and determine where in the RPM band it currently makes its max horsepower. We then work through the combinations of advance on the inlet and retard on the exhaust until we achieve the highest reading at the predetermined rpm. We may move up a down a little in the rpm range just to make sure the adjustments have not altered the maximum power rpm point. Generally speaking there will be little if any adjustments required in the fuel and ignition maps. This process normally nets a 10 to 15 bhp increase at that rpm, but sometimes we loose as much as 10 bhp in the lower rpm positions.
Setting the cam timing up for best responsiveness is a lot more difficult as you are tuning through a range of rpm not just a single point. The way we do it is to tune as above but at the maximum torque rpm. Depending on the boots rise, we are aiming to increase the torque for at least 1,000 to 1,500 rpm around that point. We find that in order to get a good increase we need to change the ignition and fuel maps. Typically we will get a 20 bhp increase at that rpm, but loose up to 10 bhp at the maximum horsepower rpm.
Once we finish on the dyno, a road (better is track) test to confirm we have achieved not only a torque increase but a response increase as well. Our experience has been that if we have to make large changes in the ignition and fuel maps we will get a big improvement in response. Conversely if we only make very tiny adjustments, the response improvement is not as great.
Hope that helps.
thanks, it turns out this isnt really what im after. top end is fine on my car and makes big power. but due to the large turbo it lacks driveability, ive downsiezed the exhaust wheel from a 2.24" to a 2" but without the desired effect. i want full boost by 3500rpm, maybe with a turbo that big im dreamin
Hi adam32 again, anything that increase the temperature of the exhaust gas improves turbine rpm. So if you ceramic coat the inside on the combustion chambers, valve heads, piston tops and exhaust ports you reduce the temperature loss into the head and ultimately water jacket. The car runs lower water and oil temperature but higher exhaust gas temperature.
Higher temperature = more energy, more energy = higher turbine rpm, higher turbine rpm = more boost at lower engine rpm.
I can't give you real world example on a Skyline as we have always tended to do other things at the same time as we are ceramic coating. But I can tell you that in the targa Lotus we noticed a 10 degree decrease in the water temperature, a 7 degree decrease in the oil temperature and a 30 degree increase in the exhaust gas temperature. Turbo boost reached 1 bar 250 rpm earlier in the rev range.
It is certainly something we do regularly on the team cars, and our personal RB31/RB26 hybrid is having it done as I write this.
Hope that helps.
 Share
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
