just a few questions on these adjustable cam gears
a) whats a good price for them
B) should you use buy both inlet and exhaust?
c) do they confuse any ECU's?
d) whats involved in setting them up and tuning them?
e) under what situation are they recommended ie for a heavily tuned vehicle, to reduce lag, increase tuneability??
thanks
adam
https://www.sau.com.au/forums/topic/12834-hks-cam-gears/
Adam,
They cause the cam overlap to change, meaning the cylinder fill is different.
Most R33's use the exhaust cam gear only, as the inlet gear removes the variable cam timing, but I don't think RB20's have NVCS.
Easy to install, rev210 did his in under 1 hour.
See'ya:burnout:
https://www.sau.com.au/forums/topic/12834-hks-cam-gears/#findComment-239632
Usually about 5kW per cam gear on stock cams, more if you have aftermarket cams.
If can reduce lag, but most people use it for top-end power, which reduces power down low.
You can dial in the gears for top-end power or mid-range torque.
See'ya:burnout:
https://www.sau.com.au/forums/topic/12834-hks-cam-gears/#findComment-239691
Hi adam 32, by changing the overlap/separation on the inlet and exhaust camshafts you can most definitely improve the responsiveness of the engine.
However it is a lot easier to set them up for maximum horsepower, we simply run the car up on the dyno and determine where in the RPM band it currently makes its max horsepower. We then work through the combinations of advance on the inlet and retard on the exhaust until we achieve the highest reading at the predetermined rpm. We may move up a down a little in the rpm range just to make sure the adjustments have not altered the maximum power rpm point. Generally speaking there will be little if any adjustments required in the fuel and ignition maps. This process normally nets a 10 to 15 bhp increase at that rpm, but sometimes we loose as much as 10 bhp in the lower rpm positions.
Setting the cam timing up for best responsiveness is a lot more difficult as you are tuning through a range of rpm not just a single point. The way we do it is to tune as above but at the maximum torque rpm. Depending on the boots rise, we are aiming to increase the torque for at least 1,000 to 1,500 rpm around that point. We find that in order to get a good increase we need to change the ignition and fuel maps. Typically we will get a 20 bhp increase at that rpm, but loose up to 10 bhp at the maximum horsepower rpm.
Once we finish on the dyno, a road (better is track) test to confirm we have achieved not only a torque increase but a response increase as well. Our experience has been that if we have to make large changes in the ignition and fuel maps we will get a big improvement in response. Conversely if we only make very tiny adjustments, the response improvement is not as great.
Hope that helps.
https://www.sau.com.au/forums/topic/12834-hks-cam-gears/#findComment-239832
thanks, it turns out this isnt really what im after. top end is fine on my car and makes big power. but due to the large turbo it lacks driveability, ive downsiezed the exhaust wheel from a 2.24" to a 2" but without the desired effect. i want full boost by 3500rpm, maybe with a turbo that big im dreamin
https://www.sau.com.au/forums/topic/12834-hks-cam-gears/#findComment-239834
Hi adam32 again, anything that increase the temperature of the exhaust gas improves turbine rpm. So if you ceramic coat the inside on the combustion chambers, valve heads, piston tops and exhaust ports you reduce the temperature loss into the head and ultimately water jacket. The car runs lower water and oil temperature but higher exhaust gas temperature.
Higher temperature = more energy, more energy = higher turbine rpm, higher turbine rpm = more boost at lower engine rpm.
I can't give you real world example on a Skyline as we have always tended to do other things at the same time as we are ceramic coating. But I can tell you that in the targa Lotus we noticed a 10 degree decrease in the water temperature, a 7 degree decrease in the oil temperature and a 30 degree increase in the exhaust gas temperature. Turbo boost reached 1 bar 250 rpm earlier in the rev range.
It is certainly something we do regularly on the team cars, and our personal RB31/RB26 hybrid is having it done as I write this.
Hope that helps.
https://www.sau.com.au/forums/topic/12834-hks-cam-gears/#findComment-239860
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
