Cam Gears, Adjusting me and a mate where talking about my skyline and getting 200rwkw I said I need a computer and a Adjustable cam gear he said try and skip the belt over one tooth that should be about -4degrees and see how it goes, what do you guys think about this could it work. :cheers:post-28604-1154350017.jpg
Edited by RB SANDY
https://www.sau.com.au/forums/topic/128342-cam-gears-adjusting/
so are cam gears really worth it
I'd say its different for every car
Cam gears do give you a lot more options with tuning and your powerband, such as:
Advancing Intake and Exhaust: This will provide the car with more bottom end power, and will decrease top end. Advancing both cam gears will move overlap earlier but will not increase it.
Retarding Intake and Exhaust: This will increase the cars top end, but will decrease low end. Retarding both cam gears will move the overlap later and but will not change the amount of overlap.
Advance Exhaust Only: This will help the cars top end, and it reduces overlap.
Retard Exhaust only: This will help the cars mid range power, very useful for cars with big turbos / big cams. By increasing overlap, It decreases lag significantly. Doing this will bring the boost on all at once.
Advance Intake only: This will increase overlap and helps the cars bottom end and mid range power. This mod will bring the turbo on all at once.
hang on are you saying you want to buy cam gears and adjust them one notch... or are you saying that the alternative to buying cam gears is to skip one tooth on the stock gears??
each tooth is 15deg, so skipping one tooth, as you say, will make it way way out and is a stupid idea
Mate I have looked into this and it comes down to this some people gain power some do not. Im getting my 100K service done shortly and getting a exhaust cam gear installed while I am at it. Apprantly the idea is to retard the timing by about 4 degrees it is meant to give you increased midrange and top end power. I will get the car dyno tuned and post before and after results.
mods are
full 3" exhaust
intercooler (hybrid)
11psi boost
safc2
195 rwkw
cheers
some people say you can gain up to 10hp
If you can feel a 7kw difference... that will surprise me.
Im yet to see conclusive evidence the cam gear will be of benefit on an stocker RB25
RB26, lots to gain, but you dont have one of those.
on a side note you can use the stock cam gears with a dongle fitted to adjust them. mine has a dongle fitted to make the exhaust side adjustable (gained nothing). so you can retain vct and have them adjustable
everyone is missing the point here...
HE WANTS TO ADUST HIS TIMING BELT WITHOUT ADJUSTIBLE CAM GEARS
that's right, with stock gears
this is NOT possible. please DON'T do it. ditch the idea completely.
That is all.
Correct, some one picked up on it.. You need to adjust the actual cam shaft not the gear on the belt.. If you wish to invest in such item take it to a workshop that can do the work for you.
i suppose in ways your right but what your talking about is really inefficent. what u want to do is to increase the overlap keeping it symetrical. u want the intake to open earlier and the exhuast to close later by the same amount. so really u want to advance the intake and retard the exhaust. Defintly do not time the belt incorrectly by one tooth because theres a big difference between the valve being open enough to pass gasses & the valves hanging down low in the path of the piston. In respect to do they make a difference i say yes. it works on the kadenacy effect. it already exists but you just take further advantage of it which is exactly how extractors work and we all know they make a difference. it's also what vtec does & we all know how much power honda can get out of a na 4cyl engine.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
