Hey guys,
Driving home tonight gave it a squirt in first put it into second, full throttle and then when it came onto full boost I hear BANG and the whole car jerks and theirs a massive rattle sound coming from the gearbox,
I quickly pulled over and turned the car off had a look underneath to see if anything was fallen off or anything but coudlnt see anything out of the ordinary, got back in the car started it, MASSIVE rattling sound coming from the gearbox on idle even when the car was in neutral, car very hard to get into gear, took off in first took off very hard just that massive constant rattle, everytime I tried to put it into second I just get a massive bang and the whole car jerks and it wont go in so I managed to baby the car home in 3rd (with that loud rattling noise still going constantly seems to ease up a bit when the clutch it put all the way in and the car is idling)
Ive booked a tow for the morning to get the car to a workshop but does it seem like the gearbox is gone?
Why do these things happen at the worst times was just preparing to put my new turbo on and fix some other things on the car :cheers:
Edited by Dave69001
https://www.sau.com.au/forums/topic/128343-did-i-just-kill-my-gearbox/
if it's at idle (in neutral), its likely that it's the clutch and not the gearbox
because obviously nothing in the gearbox should be moving in neutral
does it still make the sound if you push the clutch pedal in?
Hmm hopefully thats what it is mate I just replaced the clutch with a heavy duty one 2 months ago though so not sure why it would of caused this.
Yeah it does seem to go away if you put the clutch in and its idling but when I was babying it home whenever I put the clutch in as the car was going along it would still do it but I guess the gearbox would still have things moving if the cars moving right?
Edited by Dave69001
Sounds like the g/box is gone, when in neutral the main shaft still turns . The only time it doesn't is when the car is not moving and clutch pedal pushed in.
you learn something new everyday!
thanks for clearing that up :cheers:
to put it plain and simple:
if your car is rolling (clutch in OR out)- there will be a section of the gearbox that is moving.
if the clutch pedal is out, and its in neutral (regardless of rolling or not rolling) there will be a different section of the gearbox thats moving.
to get a very good understanding of how gearboxes work i reccomend this link:
http://auto.howstuffworks.com/transmission.htm
your description to me sounds like your gearbox has been raped.
my condolences for your loss (as much as i like to be right, i hope im wrong). i hate it when bad shit happens to pride and joys.
cheers. james.
EDIT: took me so long to write this up, your question has been answered before i finished! but atleast i supplied a good link! cheers.
Dude if you are upgrading to a bigger turbo I would change to an R33 gearbox as 20 ones are fairly weak. Is a bit more expensive but better in the long run as its 1 less thing to worry about busting all the time.
Shit bad luck dave and you haven't even been able to put my turbo on yet!! :P
Although R33 boxes are stronger, I can't see the need to upgrade to one unless your pulling some decent figures already, and plan to take the car alot further power wise.
FRom what i've been told you need the g/box itself obviously, approx $1500, get it fitted, and i'm pretty sure you also need a custom made tailshaft, and alot of other crap to get it working.. it's a costly exercise, but you would never have to worry about breaking the box again!!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
