Hey guys
I recently got into a bit of a bang with my R32 GTR , but the only thing damaged was the front bar... none of the internals got hurt
Now, driving the car to the panel beaters i had NO reponse, i couldnt hit 3k rpm without flooring it, the car was making the most awful noise like it was struggling massively... now, remember none of the internals were damaged at all, even the front mount was fine...
When u push it, it'll backfire, but it just keeps making this Pttt ptttt ptttt ptttt pttt noise and will never hit boost.
WHAT THE HELL IS WRONG WITH MY CAR!???!?!?!!?!?!?
I was told it could be the crank angle sensor? and that they move slightly and it totally screws up ur car? Or the CAS connection?
HELP please !!!!!!!!!!!!!!!!!!
https://www.sau.com.au/forums/topic/128352-massive-problem-i-mean-massive/
on inspection, the intercooler was fine, just pushed in a little and moved to one side, but nothing major? could i not be seeing something?
Broken IC would be my guess too.. like Craved said if it's moved across something would have to bend/loosen for it to move.
Cheers boys... i feel much better now... cause i know i can just tig weld anything if there are holes.... or if its the clamps i'll just get new silicon hoses :D
THANKS A HEAP BOYS!
(and girls if any replied) :sorcerer: :sorcerer:
The engine will still rev past 3 if one of the pipes comes loose or there is a small hole. Check to make sure your AFM is connected properly and spray some aerostart around all the pipe connections while the engine is running just to be sure.
Also check your Catalytic converter to make sure it might not be blocked. Might just be a coincedence that it happened at the same time as the accident.
As for the CAS...why would it be the CAS when there was hardly even damage to the bumper?
cool... cheers man
as for the CAS, the panel beater didnt know what he was on about
it turned out to be a gash in the cooler.... i cbf getting it welded.... so i'm gonna chuck it out and get another FMIC
(btw the one i'm chucking out is a TRUST FMIC) :D
cheers again boys
Yeah id say it sounds like an AFM metre problem. My friend has a 32 GTR and his connection was loose and it wouldnt let him rev past about 3000rpm.
Chris
he just said that it was a gash in the intercooler. so it wasn't afm.
cool... cheers man
cheers again boys
How bad is the damage on the trust FMIC your throwing out..?
Weldable?
obviously you don't think so since you were prepared to tig up damage..
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
