  • Replies 108
Posted Images
Does it look fixable? i also bent the passenger side rear control arm and some rod thats part of the HICAS stuff..........
Am trying to source parts at the moment.
Is ther any chance i can scab a lift off someone if i dont get my car back on the road? but its a 99% chance the car will be back on the attack for teh nasho so relax, its not hard! anyhow have a winfield!
ouch.. New rims time ;)
remove hicas all together lol
im sure someone will give ya a lift...
Yeah i agree - new rims
AND get rid of HICAS while fixing whatever's broken in there
So far, there's 4 people scabbing lifts for this one :(
So far, there's 4 people scabbing lifts for this one :O
4 People! DAM! Hopefully i will get it all soughted by Friday night - just like the last nasho run....... Had a fcuked thrust bearing and had to change it on the day FUN FUN FUN!
:O
What ze fick
Someone is going to get stabbed muhahahah
Can i get a lift off someone aswell now ? :lol:
What ze fick
:P
Unlucky - i just forked out 2 grand to fix my car from been a tool and running up that dudes ass whilst checking out a hot chick and now this. :rofl:
Slide bring on teh crayons! If my car is back on the road you riding with me bish! fingers crossed!!!!
Unlucky - i just forked out 2 grand to fix my car from been a tool and running up that dudes ass whilst checking out a hot chick and now this. :huh:
:sorcerer:
hahahahah
w00t be there soon
Everyone go it will be fun
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
