Hi terry call captain thread on 0407077414 he will remove it for you. Tell him FOOLBOOST says hi :P
Excellent, thanks mate. Do you know how much $$$ roughly?
Do you know if this causes any boost issues?
if you're lucky, that exhaust port will still seal and there will be no change.
otherwise yes, of course.. you will get an exhaust leak which means there is less gas available to drive the turbo and your car won't boost as quickly.
The stud breaks because the leak was already there or because of an oil leak over the stud in question. So to answer your question - yes it will cause boost issues.....it will also effect air/fuel ratio readings. If one stud is broken you will be looking at around 4 -5 hours but the thread guy will not remove the turbo and manifold for you...you'll have to do it yourself or get someone else to do it.
just done mine lol worksshops charge 50 or more per stud to fix plus gaskets lol and so on..
i done myself they suck,,need small air drill if have some snapped of...
replace all of them if doing not worth doin 1 or 2
goodluck
captain thread is the MAN!!! he has gotten mine out twice, when i broke an easy out stud extractor off in the broken stud aswell...
cost a bit over a hundred $$ EACH. but i was so frustrated i had no other avenue. He has a mobile service which is very handy
VOTE 1 CAPTAIN THREAD
ive had this same problem, and now i got an oil leak from the head behind the stud.. i called a thread proffesional to fix it, and its still leaking, is there anything i can use to seal this leak properly? rather then replacing the whole head?
i've heard of exhuast studs breaking on many skylines. it was probably a techline in japan
they break because the inline-6 manifold is long, and has a turbo hanging off it. the weight and flexing from repeated heat cycling gradually fatigues the studs.
I had at least 3 snapped studs when I pulled the manifold off my R31 (was upgrading the turbo and figured I should do the studs while it was apart). I didn't suffer from any exhaust leaks either.
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
