You need a S2 bonnet and grille, the guards are the same. Do a search.
But why bother, you can fix up the head lights (search for this too) and you have a S1, I dont understand why you'd want to turn it into something it isnt. Also the S2 headlights do the same after time anyway.
I wouldn't say they're better in any way. They look better with the S2 front bar as they're a bit newer, however the GTR kept the same shape through the entire GTR series, the only update they had was the xenon low beam.
If your going to spend several thousand in converting to S2 headlights, front bar and bonnet, why not buy some S3 GTR xenons.
Yeah but there is a bit of a price difference between GTST gear and GTR gear. Have you seen how much the series 3 xenon lights go for?? I think there like 2 or 3 grand new from nissan and around 1500 2nd hand.
Series 2 GTST lights wouldnt even be worth half that.
Chris
its still a waste of money doing a conversion imo
especially since the only reason for the conversion mentioned, is to get rid of that yellowy color which can be gotten rid of with a quick buff job.
i'll take before and after shots if i can find a before shot and show you the difference.
Agreed.
For the amount of effort and stuffing around plus the cost (say $2,000 to do it all) you could definately spend your money better in other ways. If you're not confident about buffing them yourself pay a detailer. The same thing happens to EF,EL falcon headlights so most places will know what they're doing and would cost $100 max.
Fixing your current headlights is easy, i had the same yellow tint happen to my S1.
Just buy some wax/polish, clean the headlights with water, dry it, then throw some polish over them. let it sit for a bit then wipe it off. Mine came out sparkling like new.
It's not just the yellow colour.
sII headlights have a clear lens with nothing behind it.
sI headlights have that outer lens, which has all gay patterns on it. Then it still has an inner lens. it looks pretty ugly.
The sII light looks all sparkly and nice.
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
