blackbeast Posted August 1, 2006 Share Posted August 1, 2006 Hi guys i am after series 2 headlights for my series 1 r33 cause they are turning a faded yellow Can this be done? Does anyone sell series 2 headlight made for a series 1? Link to comment https://www.sau.com.au/forums/topic/128387-r33-series-1-conversion-to-series-2-lights/ Share on other sites More sharing options...
cogs Posted August 1, 2006 Share Posted August 1, 2006 yea of course you can do it but you'll probably need S2 bonnet, front bar and maybe guards as well.. do a search its probably been covered before. Link to comment https://www.sau.com.au/forums/topic/128387-r33-series-1-conversion-to-series-2-lights/#findComment-2373475 Share on other sites More sharing options...
Bliksem Posted August 1, 2006 Share Posted August 1, 2006 You need a S2 bonnet and grille, the guards are the same. Do a search. But why bother, you can fix up the head lights (search for this too) and you have a S1, I dont understand why you'd want to turn it into something it isnt. Also the S2 headlights do the same after time anyway. Link to comment https://www.sau.com.au/forums/topic/128387-r33-series-1-conversion-to-series-2-lights/#findComment-2373497 Share on other sites More sharing options...
**JaR** Posted August 1, 2006 Share Posted August 1, 2006 get the headlights buffed, it'll get rid of that yellowy color and it will be alot cheaper than changing them ove rto S2 ones. Link to comment https://www.sau.com.au/forums/topic/128387-r33-series-1-conversion-to-series-2-lights/#findComment-2373838 Share on other sites More sharing options...
smurf80 Posted August 1, 2006 Share Posted August 1, 2006 Yeah but series 2 lights are still better! You can change them with just the front bar but they stick out. Your best to swap everything if you want it to look right. Link to comment https://www.sau.com.au/forums/topic/128387-r33-series-1-conversion-to-series-2-lights/#findComment-2374248 Share on other sites More sharing options...
Bliksem Posted August 1, 2006 Share Posted August 1, 2006 I wouldn't say they're better in any way. They look better with the S2 front bar as they're a bit newer, however the GTR kept the same shape through the entire GTR series, the only update they had was the xenon low beam. If your going to spend several thousand in converting to S2 headlights, front bar and bonnet, why not buy some S3 GTR xenons. Link to comment https://www.sau.com.au/forums/topic/128387-r33-series-1-conversion-to-series-2-lights/#findComment-2374273 Share on other sites More sharing options...
smurf80 Posted August 1, 2006 Share Posted August 1, 2006 I wouldn't say they're better in any way. They look better with the S2 front bar as they're a bit newer, however the GTR kept the same shape through the entire GTR series, the only update they had was the xenon low beam.If your going to spend several thousand in converting to S2 headlights, front bar and bonnet, why not buy some S3 GTR xenons. Yeah but there is a bit of a price difference between GTST gear and GTR gear. Have you seen how much the series 3 xenon lights go for?? I think there like 2 or 3 grand new from nissan and around 1500 2nd hand. Series 2 GTST lights wouldnt even be worth half that. Chris Link to comment https://www.sau.com.au/forums/topic/128387-r33-series-1-conversion-to-series-2-lights/#findComment-2375448 Share on other sites More sharing options...
**JaR** Posted August 2, 2006 Share Posted August 2, 2006 its still a waste of money doing a conversion imo especially since the only reason for the conversion mentioned, is to get rid of that yellowy color which can be gotten rid of with a quick buff job. i'll take before and after shots if i can find a before shot and show you the difference. Link to comment https://www.sau.com.au/forums/topic/128387-r33-series-1-conversion-to-series-2-lights/#findComment-2376187 Share on other sites More sharing options...
Bliksem Posted August 2, 2006 Share Posted August 2, 2006 its still a waste of money doing a conversion imoespecially since the only reason for the conversion mentioned, is to get rid of that yellowy color which can be gotten rid of with a quick buff job. i'll take before and after shots if i can find a before shot and show you the difference. Agreed. For the amount of effort and stuffing around plus the cost (say $2,000 to do it all) you could definately spend your money better in other ways. If you're not confident about buffing them yourself pay a detailer. The same thing happens to EF,EL falcon headlights so most places will know what they're doing and would cost $100 max. Link to comment https://www.sau.com.au/forums/topic/128387-r33-series-1-conversion-to-series-2-lights/#findComment-2376274 Share on other sites More sharing options...
R3LOAD Posted August 2, 2006 Share Posted August 2, 2006 Fixing your current headlights is easy, i had the same yellow tint happen to my S1. Just buy some wax/polish, clean the headlights with water, dry it, then throw some polish over them. let it sit for a bit then wipe it off. Mine came out sparkling like new. Link to comment https://www.sau.com.au/forums/topic/128387-r33-series-1-conversion-to-series-2-lights/#findComment-2376372 Share on other sites More sharing options...
MANWHORE Posted August 3, 2006 Share Posted August 3, 2006 It's not just the yellow colour. sII headlights have a clear lens with nothing behind it. sI headlights have that outer lens, which has all gay patterns on it. Then it still has an inner lens. it looks pretty ugly. The sII light looks all sparkly and nice. Link to comment https://www.sau.com.au/forums/topic/128387-r33-series-1-conversion-to-series-2-lights/#findComment-2381859 Share on other sites More sharing options...
braadz Posted August 4, 2006 Share Posted August 4, 2006 just rub out the yellow with wet rub paper, i used 1200grit 1500grit 2000grit then buffed it looks brand new Link to comment https://www.sau.com.au/forums/topic/128387-r33-series-1-conversion-to-series-2-lights/#findComment-2382600 Share on other sites More sharing options...
