Hi all,
I have a 3" cat back kakimoto exhaust. I am looking at getting either a bigger cat of split front dump pipe. I cant afford both at the same time. So, which should i get first. I am leaning towards the cat as its much easier to install, but am intersted to know more.
https://www.sau.com.au/forums/topic/128389-bigger-car-or-front-splitdump-pipe/
I say save up more money and do both at the same time. I just find jacking up the car somuch of a hassle. Then you have to undo the tight exhaust bolts.
well, that's what I did anyways. Did it all at once and never looked back.
Keep in mind, that the dump/front pipe might be a tiny bit longer or shorter or in the wrong place. so it might require fiddling and stuff. Mine required the cat to be modified.
so do it together.
Mate dont f**kin start me on this money crap lol. Spending money is how i deal with personal life being f**ked.
LOL - sound like me.
why do you "need" a split dump pipe?
looked into a simple turbo to cat-converter 3inch stainless pipe, and a 3inch highflow cat-converter? this combo would be less in cost (at the most, equal in cost) then a split dump pipe on its own.
JustJap 3inch stainless steel dump pipe (turbo to catconverter) = ~$220 + $20 delivery
3inch highflow cat-converter = ~$150 + delivery
both the above can be found on ebay, lol
I did my cat today with one of BATML's small body cats on a RB20DET. The amount of carbon and crap that was in the inlet of the original cat was amazing. There was atleast a half centermeter of crap embedded on the pipe plus all the crap that was clogging up the mesh.
There wasn't a huge difference in power (but noticable) but the car was alot smoother without so much restriction in the exhaust.
Dump pipe is next to go on :D
Also, do it yourself! Its only 4 bolts ffs
It took me about 2 hours of screwing around. The main problem was the cat back pulling like a spring toward the back of the car. Made it a bit of a pain the ass to get back together, if I had somone helping it would have been alot easier. I think swearing definately helps it to go on.
Dump pipe will probably be a bit harder. Just get a can of RP7 and a cheap socket set and go nuts ;)
I dont have the tolerance, patience, or desire to do any f**king around on the car myself at the moment. I'd be more inclined to smash the shit out of it in personal frustration. Dont think i am kidding.
I definitely want the big cat off BATML's group buy, as for front/dump pipe... i dont really care as long as its good.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
