JustJap are selling these quick release steering wheel hubs: http://www.justjap.com/parts_ninterior.htm
I've been told by them that they make the steering wheel stick out further from the dash about 60mm. Does anyone who has one of these (or something similar) find it annoying that the steering wheel sits this far out?
https://www.sau.com.au/forums/topic/128401-quick-release-steering-wheel-hubs/
Thats correct, the steering wheel sits closer to you, which in many cases is a good thing. I have used one and not only are they great for track use but make a top theft deterrent :P
Best theft deterrent ever.
Just chuck your wheel underneath your seat when you leave your car..
If I didn't have an airbag wheel I'd get one ASAP.
Yeah that's what I was thinking. For $99 it's relatively cheap too!
That'll probably be the least of your worries if you're getting defected for other stuff :P
I'm not too sure about the legalities though. i haven't heard of that one before, although I wouldnt be surprised if this was the case!
yes it is illegal to switch to a non-airbag wheel. and I would say they are definately illegal.
BUT
I have bought 3. One for the alfa race car, one for the GTR (track/street) and one for the GTST. They are pretty good. and certainly great value. My only gripe is that being ball lock type there is a little bit of play introduced as opposed to a spline lock type (used one of those too). The spline lock ones (sparco etc) typically cost around $350 though and even one of those went wrong once when my friend didn't have it properly engaged on his GT3 Cup Car and the wheel came off in his hands...!
I haven't had any of the 3 just jap ones fail on me yet and I've removed the safety catches for ease of use. (do it at your own risk!).
I was a little hesitant when I saw you say that they introduce play into the wheel. Is it noticable?
I guess if you bought a further two for other cars it can't be that bad though?
I've got a quick release that looks almost exactly the same as the Just Jap ones except mine is from Japan (assuming the Just Jap ones are copies?). The build quality is so tight that it has absolutely zero play in it at all, in fact I would go as far to say that it's a little too tight, as getting the wheel off takes some fiddling around.
The only gripe I have is that the indicator stalk is now just out of reach of fully stretched fingers... lol
I haven't noticed any play.
They're certainly illegal on cars with factory airbags, I've painted mine matt black in effort to keep it looking bland.
I sleep alot better leaving the car on the street over night at the gf's place knowing its going to be pretty hard to swipe the car with no wheel.
Damn, that seems like such a little thing but I swear it's exactly the kind of little thing that would give me the shits after weeks of use.
Yeah at first glance
What happens if they break into your car and find the wheel under you seat?? pretty pointless leaving the thing in the car.
Edited by the97skyline
Too bad then I guess.. Like I said, it's a deterrent - it's not a solution for car theft.
Not sure how a car thief thinks, but they may have second thoughts about stealing a car which from the outside does not have a steering wheel.
And if not in the car (under the seat/in the boot) where else would you put it if you detached the wheel? I wouldn't want to be carrying a Momo around when walking through a shopping mall for 3 hours ;)
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
