JustJap are selling these quick release steering wheel hubs: http://www.justjap.com/parts_ninterior.htm
I've been told by them that they make the steering wheel stick out further from the dash about 60mm. Does anyone who has one of these (or something similar) find it annoying that the steering wheel sits this far out?
https://www.sau.com.au/forums/topic/128401-quick-release-steering-wheel-hubs/
Thats correct, the steering wheel sits closer to you, which in many cases is a good thing. I have used one and not only are they great for track use but make a top theft deterrent :P
Best theft deterrent ever.
Just chuck your wheel underneath your seat when you leave your car..
If I didn't have an airbag wheel I'd get one ASAP.
Yeah that's what I was thinking. For $99 it's relatively cheap too!
That'll probably be the least of your worries if you're getting defected for other stuff :P
I'm not too sure about the legalities though. i haven't heard of that one before, although I wouldnt be surprised if this was the case!
yes it is illegal to switch to a non-airbag wheel. and I would say they are definately illegal.
BUT
I have bought 3. One for the alfa race car, one for the GTR (track/street) and one for the GTST. They are pretty good. and certainly great value. My only gripe is that being ball lock type there is a little bit of play introduced as opposed to a spline lock type (used one of those too). The spline lock ones (sparco etc) typically cost around $350 though and even one of those went wrong once when my friend didn't have it properly engaged on his GT3 Cup Car and the wheel came off in his hands...!
I haven't had any of the 3 just jap ones fail on me yet and I've removed the safety catches for ease of use. (do it at your own risk!).
I was a little hesitant when I saw you say that they introduce play into the wheel. Is it noticable?
I guess if you bought a further two for other cars it can't be that bad though?
I've got a quick release that looks almost exactly the same as the Just Jap ones except mine is from Japan (assuming the Just Jap ones are copies?). The build quality is so tight that it has absolutely zero play in it at all, in fact I would go as far to say that it's a little too tight, as getting the wheel off takes some fiddling around.
The only gripe I have is that the indicator stalk is now just out of reach of fully stretched fingers... lol
I haven't noticed any play.
They're certainly illegal on cars with factory airbags, I've painted mine matt black in effort to keep it looking bland.
I sleep alot better leaving the car on the street over night at the gf's place knowing its going to be pretty hard to swipe the car with no wheel.
Damn, that seems like such a little thing but I swear it's exactly the kind of little thing that would give me the shits after weeks of use.
Yeah at first glance
What happens if they break into your car and find the wheel under you seat?? pretty pointless leaving the thing in the car.
Edited by the97skyline
Too bad then I guess.. Like I said, it's a deterrent - it's not a solution for car theft.
Not sure how a car thief thinks, but they may have second thoughts about stealing a car which from the outside does not have a steering wheel.
And if not in the car (under the seat/in the boot) where else would you put it if you detached the wheel? I wouldn't want to be carrying a Momo around when walking through a shopping mall for 3 hours ;)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
