Damn, that seems like such a little thing but I swear it's exactly the kind of little thing that would give me the shits after weeks of use.
Ditto :)
Do you have the same prob with the justjap one Richard?
Ditto :)
yeah, it probably extends the wheel towards you (and away from the idicator stalk) about 80mm all up. doesn't really bother me. But it means you will have to take your hand off the wheel to indicate.
I got one mainly for the fact that it brings the wheel closer and I don't have to have my legs crouched under the steering wheel column to get a decent reach.
The horn has contact switches on the both parts of the lock kit.
I can't notice any play in the wheel although the quality doesn't seem to be 100% as it is a little rough in the finishes, but nothing structually
wrong with it. Check them out on ebay, they are made bt D1 spec and I got mine for about $70 (from just jap on ebay)
do these have provision for the horn button wiring?
Yes. It's a complicated system of brass fittings and contact points.... lol
Seriously it's just like an 'extention' of the same thing they use on aftermarket horn buttons.
I've sat in a car with one of these before. I can reach the indicator stalk fine, but I have crazy long fingers.
TRUE
Get the misses to hold it :P
Ha ha, yeah that's what handbags are for! But if you were at someone's place you could always take it inside. If you were at a shopping centre you could probably hide it underneath the carpet in the boot that covers the spare wheel. It's a bit of an extra hassle though.
I bought a chargespeed quick release system which has a ball type lock and its very tight...there is almost no play what so ever. I did however buy a D1 version initially but i returned it for the chargespeed as it had quite a bit of play and moved around way to much for my liking... just my 2 cents.
look, there is nothing majorly wrong with the just jap ones. think about it. a 'proper' splined one costs around $350. a just jap one costs under $100. So it's a bit unreasonable to expect it to be perfect. With the ball lock there will always be a tiny bit of play. other than that they are fine. the fact they move the wheel 10cm back is a given, every brand does that. like I said I have 3 (but I've also bought another one for a mate). 2 of the 3 have seen track use, and 1 of the 3 has been used for probably 200laps at 5 race meets + practice days in 12 months. it's not as tight as it was, but it hasn't let us down in any way either. and it means I can get into the seat without having to swan dive through the opening in the roll cage.
key points:
* yes you will need an aftermarket wheel AND boss kit (so if you want to keep factory wheel, or have an airbag wheel, it's not for you)
* yes it spaces the steering wheel further towards you (so most likely you will need to take your hand off the wheel slightly to use indicators)
* yes it's most likely illegal for street use (but so is probably 3/4 of your aftermarket parts)
* yes if you can afford it one with a spline system is better (but more than 3 times the price)
* BUT, if it's what you want the just jap ones cannot be beaten for value for money. I would not have bought 3 more after the first one if they were sh1t.
here endeth the lesson!
I was under the impression it was legal to remove an airbag wheel if the airbag was optional in the first place?
Im sure i read that on boostcruising forums one day....
no. If a car was factory fitted with an air-bag wheel, it cannot be replaced with a non-airbag wheel.
  • 2 months later...
I spoke to the RTA on this, and if the airbag was an option or if the car continues to comply with ADRs (for padding and size etc) after the removal it is legal in NSW, i have a GTR and they said it is legal for me to remove the wheel in it and swap it for a non airbag one
  • 4 weeks later...
if your car was delivered from factory (option or standard equipment) you cannot replace it with a non air bag wheel. i have a series 1 r33. while airbag was an option my car was not ever fitted with one. i can fit a tennis racket if i like.
as long as its the right diameter and all that lol
    • Yeah, they look good. I should try to fit them on mine. But being a GTSt, the guard shape probably doesn't suit properly.
    • Nah, it's not a simple voltage divider. I'm not enough of an electronics guru to know how they make these circuits work. If I had a better idea of how the ECU's temperature measuring is done, I could then actually do as you want, which is turn that resistance chart into a voltage chart. But my approach has not worked. What I did was interpolate the sensor ohms values for the temperatures you listed, as you did not have any of them on a temperature ending in zero or 5. These are: °C ECU V sensor ohms (interpolated) 58 2.68 11.85 57 2.7 11.89 56 2.74 11.93 54 2.8 12.01 49 3.06 12.208 47 3.18 12.284 43 3.37 12.42 I then assumed 5V supply to the resister and calculated the voltage drop across the sensor for each of those, which is just 5 - the above voltages, and then calculated the current that must be flowing through the sensor. So you get:             Values in sensor °C ECU V sensor ohms (interpolated) Supply volts Volt drop Current 58 2.68 11.85     5 2.32 0.195781 57 2.7 11.89     5 2.3 0.19344 56 2.74 11.93     5 2.26 0.189438 54 2.8 12.01     5 2.2 0.183181 49 3.06 12.208     5 1.94 0.158912 47 3.18 12.284     5 1.82 0.14816 43 3.37 12.42     5 1.63 0.13124 And then use that current and the ECU's sensed voltage (which must be the voltage drop across the in ECU resister is there is one) to calculate the resistance of that in ECU resistor. You get:             Values in sensor   Other resistor °C ECU V sensor ohms (interpolated) Supply volts Volt drop Current   Volt Drop Resistance 58 2.68 11.85     5 2.32 0.195781   2.68 13.68879 57 2.7 11.89     5 2.3 0.19344   2.7 13.95783 56 2.74 11.93     5 2.26 0.189438   2.74 14.46381 54 2.8 12.01     5 2.2 0.183181   2.8 15.28545 49 3.06 12.208     5 1.94 0.158912   3.06 19.25592 47 3.18 12.284     5 1.82 0.14816   3.18 21.46325 43 3.37 12.42     5 1.63 0.13124   3.37 25.67816 And that's where it falls apart, because the resulting resistance would need to be the same for all of those temperatures, and it is not. So clearly the physical model is not correct. Anyway, you or someone else can use that information to go forward if someone has a better physical model. I can also show you how to interpolate for temperatures between those in the resistance chart. It's not fun because you've got to either do it like I did it for every 5°C range separately, or check to see if the slope remains constant over a wide range, then you can just work up a single formula. I'm just showing how to do it for a single 5° span. For the 58°C temperature, resistance = 11.77+2*(11.97-11.77)/5 The calc is a little arse backwards because the resistance is NTC (negative temperature coefficient), so the slope is negative, but I'm lazy, so I just treated 58 as if it was 2 degrees away from 60, not 3 degrees away from 55, and so on.
    • Um.... This is not easy. I will have a fiddle with it, but make no promises. I think, given the explicit resistances vs temperature, and your ECU measured voltages, it should be possible to match them up. I will do that by assuming a 5V supply from ECU to sensor, find out how much current would have to flow to produce that voltage, then use that current as a .... nah f**k. That won't work. The supply voltage is fixed, but there's nothing to say that the ECU regulates the current too. Um... I dunno. I guess there's a voltage divider setup in the ECU. As in, there's another resistance between the ECU's sense terminal and ground. That way, as the sensor resistance changes, that's how they get a floating voltage that varies with the temperature, without having to control the current. Give me a minute or 3.
    • *that* is a question for chatgpt (or someone that understands maths....but I'd try chatty). Drop them the table and ask for the formula
    • Alright. Exhaust has been looked at, and booked in 'soon'. I'm not 100% convinced it's going to be as good as possible but I'm going to go with it anyway. If I get a reasonable thing that works for 10 years I mean that's twice as long as I've lived with the current one. I have a more pressing issue. I have fixed my MPVI3 (by buying a new one). Excellently, one can wire in analog 0-5v inputs to the ECU itself. I had wideband already via Serial so I also wired it in via the direct input. The idea being I can use the standalone logging without a laptop and have Wideband data in it. The other wire I thought I'd use oil temp. This is where I've gone crazy. HPTuners requires you to implement a formula so you know how much volts = how much temp. This seems relatively simple to me. However I cannot find the scale for this anywhere on the internet, nor decipher how to figure it out without removing the sensor from the car. All I know is that voltage actually goes up as temperature goes down. I am using the actual gauge, so I can see what the temp is. The signal wire has been branched off into the MPVI3. EXAMPLE: 2.68v = 58C 2.7 = 57C 2.74v = 56C 2.8V = 54C 3.06V = 49C 3.18V = 47C 3.37V = 43C I think the gauge is 50-150C. It may be more. It may be less, because I can't find it for the love of f**k. It appears all the information about the gauges I have has been scoured from the internet, but the sender is VDO 320.021 I believe the resistance chart is this How the f**k do I convert this to a voltage? Once I have a voltage... I then have to perform this transform of said voltage to show it in the scanner: https://www.hptuners.com/help/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm @GTSBoy you're probably my only hope here TEST YOUR MIGHT
