Smooooking...
Baz
 Share
One thing I've always been curious about is how people tint there tail lights, indicators etc. Is there a particular paint you can buy or a particular process you use use to tint/smoke lights or indicators? Or is it something that needs to be done professionally? In most cases I've looked at it almost looks like a dark clear paint has been spray over the top of it (or inside it?) to give it its finish.
Cheers,
Night Shades - available from supercheap etc, youll find it hidden on the shelves somewhere....
Illegal too, but looks good...
Best way, take the lights off put them side by side and do heaps of thin light coats untill you have desired darkness.....
My mate stuck a layer of gloss over them to and they look much better.,..
ive got a can of nightshades in my cupboard, along with some clear coat...
bought it with the intention to add a bit of tint to my rear indicators on my R33, but never got around to it....
should cost you about $14 for the can...look for the dude with the dark glasses on a silver/blue can with a black lid :D
depends which car, my mate did it on his black astra. looks much better, the lights dont stick out like dogs balls....
wouldnt mind doing it to my sides...
 Share
    • You could do that by all means. but yer it shouldnt be hard to get a VR30 to 400hp with an ECUtek on stock everything.
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
