Hey all
I own an r33 gts-t and i just got a new set of adjustable cam gears on the way from just jap & being a 3rd year mechanic i know how they work and all but i'm trying to find out how much overlap can be obtained before piston to valve clearance is compromised. I appreciate all inputs but i'd rather get a response off people who can give advice off facts about r33 skylines rather than just enthusiats working on there interpretation of valve timing in general. Sorry if that sounds rude.
cheers
https://www.sau.com.au/forums/topic/128425-valve-timing-overlap/
Hey all
cheers
around 8 degrees is the maximum that I would allow. You will not need anywhere near that though. You should only be aiming for about 2 degrees on the exhaust side. And if you have VCT on your 33 then the inlet cam gear is already adjustable and the aftermarket one will not fit.
i didnt know skylines had vct. i never even bothered to look. obviously they dont all have them because there normally sold in sets. when i get them i might just adjust it 2 degrees on each cam so theres 4 degrees extra overlap, take it for a spin then change to 3 degrees on each side and see which i prefer. i've already spent the money i might as well get as much power out of it as i can. Kadenacy affect is a great thing i think
I dont see how having less overlap can make the car go slower. if anything it'll just be rougher at idle. I have a series 1.5 so thats a real bumma. i'll see how its mounted maybe i can remove the vct on the inlet and put the adjustable ones on. i relise you'd know more than anyone 3lit3 it just seems weird thed sell them in sets specifically for my car. i'd much rather it be symetrical thats all
i dont think you can just remove the VCT gear, it has its own oil supply and other things
Hey all
cheers
They are a wast of time on a standard car.
im pretty sure the big VCT gear is the way of making any adjustments, and when i got my pfc tuned, my tuned was adjusting the timing on the zorst gear
i think you may be confused there. The cam angle sensor wich adjusts the timing is on the exhaust side but this adjusts ignition timing not the cam timing. the cam gear sits in behind this and isnt related to it.
All R33 GTS25-T have NVCS on the intake side
from winkipedia
Nissan Variable Cam Timing (commonly known as N-VCT, VCT or NVCS) is an automobile variable valve timing technology developed by Nissan. N-VCT varies the timing of the valves by rotating the cam shaft(s), valve lift and duration are NOT altered. The system is implemented with an electric solenoid which is controlled by the cars ECU. Some Nissan engines only have N-VCT on the inlet cam (such as the RB25DE/DET) while ot
hers have it on both the inlet and exhaust cams.
People have had mixed results with the standard turbo still in place. You only need to replace the exhaust cam gear and -3 to -4 seems to give the best results but not always as every engine is different.
cheers
from winkipedia
cheers
cheers thanks heaps
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
