I found this steering wheel in FAST! it IS a factory option!! amazing...
does it say factory option even for r34 ??????cause i figured out the old jap owner of my car had alot of aftermaket stuff on it and i recon he may of just got hold of that steering wheel when he was selling the car so he could take a sports one off??????? this is of cause if it wasnt factory option for r34.
1. What's the VIN number?
2. How do you know its a 40th Anniversary model? None of the photo's he's given you show any 40th Anniversary badging and it doesnt seem to have any of the 40th Anniversary options like front bar or spoiler. FAST will clear that up. It doesn't have to have any of the options to be a 40th anniversary but it does need the badging.
3. Bit of strange looking rust on drive side front quarter panel seem
4. Needs new tyres.
I have been on the phone to the owner a couple of times over the past week, seems like a very nice and honest guy, yes the gearstick and handbrake boots have been replaced because when he got the car there was a big rip/cut in the gearstick boot so he replaced both the boots so they match up, the funny thing is he gave me some bad news lol, his farther was driving the car and hit a dog which cracked the bumper, but its going in to a reputable panel shop on monday to get fixed (he said he hates bog so hes getting it fixed the right way, which is good) i will be getting the car check out in sometime in the next few weeks and may even get a speedo/odometer check done on it for peice of mind
The car "is" a 40th aniversary, i saw a few exterior pics of it on the website it was advertised on, has the 40th aniversary badging on the rear quater panels, it also has the plastic CAS cover (same as the r34 CAS) which only came on the 1998 40th aniversary r33's so i have read.But overall the car seems in pretty good nick i think :miner:
Edited by nizmo_freek
Have a look at the pics od the motor,Its just the little black plastic cover thats bolted to the CAS, its meant to be the same as the r34, only the 40th aniversary r33's have it, which is what i have read on this forum and that seems to be correct from all the other series 1's and 95,96 and 97 r33's i have seen pics of.
CAS=crank or cam angle sensor (some guys call it crank angle sensor others call it the cam angle sensor) its the round silver dome looking thing that is bolted to the front of the cambelt cover, and has a plug and wiring loom plugged into the bottom of it.It is connected to the exhaust camshaft and acts like a distrubutor on normall cars like hondas etc etc, sorry im not very good at explaining things :miner: lol
well there you go...I thought i had all the 40th anniv. differences pretty much down...but I didnt know about that 1....Looked at photos of my car when it was still in japan, and saw the cover, but i couldnt remember seeing it on the car...so was thinking maybe they left it off at compliance when they did my timing belt, water pump etc....
just went and had a look at my car, and there it is hehe
:miner: haha
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
