I planning to put on sound system to my s1R33..just wonder which 1 should i go for.
Sub woofer
1x kicker comp vr dual voice coil 10: sub 300rms
or
2x kicker ex124 12" woofer single voice coil 125rms each
amp
rockford 4 channel amp (should be P450xxx)
or
rockford 2 channel amp
or
jaycar response precision amp
Can any1 guide me?thankx
https://www.sau.com.au/forums/topic/128446-which-1-should-i-go-for/
I'd take the Jaycar because they are more value for money. And I'd take the Comp VR because sound quality is more important than SPL.
thankx for your opinion~by the way,i listen R & B and techno song.i prefer more bass. Am i have to go for SPL...2X12 inches? i know the comp VR give me better sound quality.
I like the idea of 1 PHAT 12" and a good 4ch amp for powering the sub and front splits....you have splits right?! :laugh:
ya...i have. PHAT?sorry i'm new to this forum....some word i cant really understand...forgive me...thankx anyway for your good opinion.
I have a single 12" and the JayCar 4x100w response amp. The 12 has TONS of bass (too much if you turn the gain up much). Still, my old amp gave the same kind of power...
The JayCar amp fits next to the battery behind the battery false wall, which is handy, but a 12" or two 12's will completely fill your boot. =-[
go for the dual voice coil with a d class amp, MMMmmmm d class
thankx for you guys opinion~i think i will go for the 4 channel amp and the 1x 10" dual voice coil~coz twin 12" really fully fitted in my car's boot...
i'm aftering for those bass and i feel my throat vibrate~can the 10" make it?
One word.
FUSION.
If you want good quality relaible products check out their encounter range. If you want to go something a bit more go for the powerplant range.
If you would like the best deal on Fusion PM me and I will refer you to a Fusion specialist.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
