I've used Tech wax. Its not bad but because it has minor abrasives in it, there is little point using more than 2 layers because you'll just be rubbing off the previous one. You'll definitely need to prep the car first before using tech wax. Something with a mild polish like Meg's ColorX would do the job nicely!
Im with Nate31. That zamol stuff is nice gear hey. Bloody exxy tho, the top of the line stuff is $13k (yes $13 000, but free refils for life). Look on their website for the stockest of it. Most of their gear is natural product.
The clay works awesome. You can see the grim on the clay. Once your done you can run your hand over it with your finger nails and feel how much smoother it is. I really is a MUST if your doing it properly. Makes a massive difference.
Waxed my R32 today :)
Used a single coat of Meguiars Yellow Tech Wax and left it in the sun whilst I vacuumed the car. Buffed it out with a orbital buffer and got all the little bits with a microfibre cloth.
When I first got the car it had heaps of swirls. I washed, clayed and washed again. I went around a few times with the orbital buffer and some megs fine cut cleaner #2. Then I did the tech wax. Came up perfect for 13 year old paint. I just need some touch up paint to get rid of all the stone chips and scratches now.
Megs Crystal polymer sealant is also decent substitute for the Tech Wax if you not into waxing your car every month. Shine isn't as great but it lasts for ages. I used it on my parents cars and they came up great after a cut and polish. They still look clean after 3 weeks now.
Photo was taken with my phone so excuse the quality
All this talk about claying, I thought i'd give it a shot tonight. So off to Motoquipe and $40 later, i had the Meguires Quik Clay pack.
Man that stuff works a treat... the amount of gunk that was on my bonnet surprised me. I also used it to remove the usual japanese pollutants off my window.
Highly recommended.
So after you clay, what do you puy on next Nate?
(writing my shopping list..lol)
It should go something like -
Wash with degreaser/detergent (to remove wax/polish)
Claybar
Wash again
Polish (with swirl remover if needed)
Wax or Sealant
u guys do relise that wax is bad to use on ur car, if u ever need a respray or are plannin on getting one, wen u rub it bac an try an paint over it the paint doesnt like sticking, trust me my dads a panelbeater an it happend to my vl.
there for no wax for me.
If the repairer cant remove the wax they havent prepped enough (their problem not mine)
Polymer finishes are usually worse than wax as they can penetrate deeper into the paint (agin a good prep will fix this)
If the painter cant get the wax out of the paint, ask them to take it back to metal.
hey pals, abit off topic but what orbital buffers do you use?
i was thinking about just buying a shitty gmc orbital buffer and some good quality microfirbre buffing cloths.
will this do or should i save and buy a better quality buffer?
cheers
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
