VINS you want "fasted"
Thanks heaps.
Just proves what I already thought.
Its a plain old GTR with a heap of NISMO stuff thrown at it. We cant have everything now can we...
Been looking for a decoding guide like that. Added to favourites now.
Edited by SSHatch
hi there,
can someone pls decipher these details as i want to know the exact year build date & associated info:
VIN: BNR32001881
MODEL: KBNR32RXFSLM2G
thanks in advance :spank:
here is your fast mate
Use this link to decode your model code
http://www.users.on.net/~goofyhsk/info/chassis_plate.html
And for the last 4 letters LMZG go back to page 39 of this thread, 10 posts down i posted what they stand for.
thanks!
L - Projector Headlights (it has this)
M - climate comtrol + upgraded stereo (it has this)
(Package Extras Sign)...
Z - Black Interior Trim (it has this)
G - ABS & Viscous LSD (it has this)
interesting about the LSD as i had this looked at not long & the builder mentioned that my diff was not stock, had nitrated gears with a nismo centre, now im not sure if this was done by the previous owner OR did it come out with this from factory???
does anyone else have the letter 'G' in their model no. or is it a 1 off an added option on my gtr?
Most of the series 1 r32 gtr's (89 - sometime in 91) that i have been asked to fast have the G on the model code.
Seems like it was an option that almost everyone got at the time of new.
The later r32 gtr's (91-94) dont have the LMZG in the model code. Just seems like nissan decided to automatically put all these options onto the later models from what i have read and remove the letters from the model codes.
The nismo centre of the diff was most likely added by the previous owner.
Edited by babyskyline
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
