VINS you want "fasted"
Here is the fast for chassis: DR30 034944
I couldnt get chassis: DR30 021333 to work for some reason.
Do you have the model code for this one??
thanks mate. So build date is 09/1983?
na not for the 2nd one. bit of a weird car, had a l24e in it with mr30 plates. all the mounts etc look factory 2. cnt see any signs of cut and weld job around the chassis number either. off 2 sims metal soon anyway lol...
Edited by OUTATIME
Heya, could I please have mine done, am trying to work out what diff is in it exacalty because noone seems to know, it has it's own stand alone ecu for the diff and has 2 oil pumps under the drivers side rear, and there is a 3rd one which appears to be attached to the diff, also has a oil top up which is located in the boot. The only thing we can read on the diff is G3HJ08, the rest of it is unreadable.
- ECR33008466
- GGKBRVFR33
Anyways thanks ;)
you almost certainly have the active rear diff, there are pumps that push torque to the side with more grip based on the wheel speeds instead of just a mechanical setup. It was on all 33 Vspec GTRs, and a very few GTSts have the option as well.
they are a good diff as long as everything is working OK, but they can be hard to troubleshoot and repair because very few people know about them, and there are few spares around
Unfortunately I can't get your vin# in my copy of fast to confirm.
Best way to check, you should have an ALSD light on your dash that you would see when you first start the car
Yeah we have the ALSD light and a slip light as well on the dash. Atm we are having issues with it staying on alot of the time. But if we get it out our drive way then turn it off and then basicly move the car as soon as we start it won't stay on. Problem is the ALSD light often comes on when any sensor in the car plays up.
Thank you for your reply, it has helped a little in trying to explain what diff we have to nissan if it is in fact the diff sensor that is running a muck lol.
could someone look into a 6u900bcnr33022973 please as supposed to be limited edition. Thanks!
Appears to be a legit limited edition r33 gtr vspec. The paint code is BT2 - Champion Blue (exclusive to R33 GTR LM)
here you go mate
Edited by babyskyline
Guys I am wondering if someone who can read Japanese can help me out here. I need to get a new door actuator for our Skyline I have fasted the VIN and worked out the part, I have even taken the part out of the car onyl to find that there are not part #'s on it. so looking at the FAST software it give me two parts #'s for the same part. Only thing that differs is the desciption and the dates, but my vehicle was made durint hte over lap of the dates so can someone tell me what is the different between the two parts and what is the correct part for the actuator ie the electronic part in the door.
thanks for any help apologies if this is in the wrong section
Edited by bigafoot
OK, 80552-AA300 is for cars with remote control entry. Other is not.
hope this helps.
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
