VINS you want "fasted"
Ok FAST guru's, i have fast on my machine, but it can never filter an import by its vin. I always have to enter the model code first, then i can enter the chassis no which will give me a build date, but i still have to enter exterior and interior colours manually. Anyone know why this would happen?
original import r32
6F4KBNR32A0016087
hope somebody can help.
cheers
sorry no luck, Australian delivered ones do not appear on nissan fast :D
hey guys,
can i please get a rundown of ECR33108743
i have a screen print of it that someone did for me a while ago, but it doesn't tell me the factory options and such.
also, does gts25tml mean it has the A-LSD?
cheers
Ric
sorry but my options list comes up in a bunch of random characters which i cant make sence of (take a look a few posts above yours for what it looks like) however it seems that it was very well optioned. maybe someone else can help out on this one?
Hey team,
chasing some info on this one
bncr33008647
thanks..
something wrong with that code, check it and come back :D
could i pllease get this vin checked
bnr32002897
thnakyou
yes you can:
Hi guys.
If you have time can you please check an pm me
ER34018661
Cheers
pm'd as requested
Thanks! :banana:
EDIT: Sorry, any idea where I can find a list of the codes so I can see what the car came with?
I'm sure i've seen it on here before somehwere. No idea what the model codes mean.
Cheers.
Edited by gersfan
Seems a little different to other Series 2's
Please Pm me as well if not to much hassle
ECR33-133451
GGKBRTFR33VDAAA-AA
Ant info would be awsome
Thanks
Hi Guys,
I have an engine number: RB25704373X
VIN: 6U90000ER34040546
If someone could shed some light on this it'd be great...
Car physically has a turbo, wanted to see whether it's a non turbo engine with a turbo strapped to it, or a turbo engine, though I'm siding to it being a conversion, but would be great to confirm.
    • What does everyone think about PSR vs Garrett? I've got a genuine G30-770 but would probably get away with a G35-900 because I've got a sequential. Are the real ones worth more than double the price?
    • @Duncan That's good to know. The luck I've been having with the car lately, a part of me was thinking something has gone wrong which is why the voltage is lower now.
    • That makes sense @Kinkstaah Would that mean the car would run as it always has until I get the tune? I’m just asking because I’m trying to understand whether I should try and get injectors and tube done at the same time. (I’d still need to drive from one place to another)   But I don’t want the car to run rich or crap itself while it’s got higher capacity injectors without a tune. Hope that makes sense?
    • Sorry I can't explain they why, but I've observed voltage is always higher at cold start.
    • so, while bored at work this week was going through some build threads and saw CRSKmD's thread and saw the free cooling improvements in the front end just by trying to direct the air better and thought i wonder how my car looks. basically, it's terrible gaps from every single point and so with some time today decided to start and tackle that.  nice and easy one to start filling in the gap at the top between the body and radiator.   then while jacking the car up found this fun surprise, never thought i would have to move it as my car isn't exactly stance nation spec but anyway decided to fix that first. so trimmed it back abit applied some primer and used some old rubber hose around all the edges to ensure it wont rub through secured it all down and while putting the fender back on realised the headlight bolt to fender wasn't installed so chucked a new one and now the headlight actually lines up with the body so big win there.   sorry for the poor pictures but went for covering up the gap between the intercooler and radiator and it took me longer than i would like to admit.   the indicators have always been really saggy and had huge gaps between them so tried to improve that and then cover up the gaps still in place to try and stop the air getting in behind them.     some awesome trimming work has been done to fit the massive China intercooler that used to be on the car but ran out of time to fix that up today sadly so plenty more to do
