VINS you want "fasted"
Ok FAST guru's, i have fast on my machine, but it can never filter an import by its vin. I always have to enter the model code first, then i can enter the chassis no which will give me a build date, but i still have to enter exterior and interior colours manually. Anyone know why this would happen?
original import r32
6F4KBNR32A0016087
hope somebody can help.
cheers
sorry no luck, Australian delivered ones do not appear on nissan fast :D
hey guys,
can i please get a rundown of ECR33108743
i have a screen print of it that someone did for me a while ago, but it doesn't tell me the factory options and such.
also, does gts25tml mean it has the A-LSD?
cheers
Ric
sorry but my options list comes up in a bunch of random characters which i cant make sence of (take a look a few posts above yours for what it looks like) however it seems that it was very well optioned. maybe someone else can help out on this one?
Hey team,
chasing some info on this one
bncr33008647
thanks..
something wrong with that code, check it and come back :D
could i pllease get this vin checked
bnr32002897
thnakyou
yes you can:
Hi guys.
If you have time can you please check an pm me
ER34018661
Cheers
pm'd as requested
Thanks! :banana:
EDIT: Sorry, any idea where I can find a list of the codes so I can see what the car came with?
I'm sure i've seen it on here before somehwere. No idea what the model codes mean.
Cheers.
Edited by gersfan
Seems a little different to other Series 2's
Please Pm me as well if not to much hassle
ECR33-133451
GGKBRTFR33VDAAA-AA
Ant info would be awsome
Thanks
Hi Guys,
I have an engine number: RB25704373X
VIN: 6U90000ER34040546
If someone could shed some light on this it'd be great...
Car physically has a turbo, wanted to see whether it's a non turbo engine with a turbo strapped to it, or a turbo engine, though I'm siding to it being a conversion, but would be great to confirm.
    • Boost leak or exhaust leak. Boost could be from anywhere, including manifold/plenum gaskets. Exhaust is frequently head to manifold gasket or from manifold to turbo gasket. Often caused by missing nuts or broken studs.
    • Check for spacers on the front, in case they've been pushed out a little to try to match he rears better.
    • I should clarify that the previous owner put the wheels on, so Im not entirely sure what he bought. I was searching the Rota page and found these two as the only matches. It did not occur to me that perhaps they sell these wheels with different offsets. I guess the best way to solve this is to take the wheels off and measure them from the inside to be sure.
    • The offset doesn't really have anything to do with dish directly. I mean it kind of does but it also doesn't, it's only tangenial. The offset is purely how much offset (get it) the mounting face is from the CENTER of the width of the rim. I.e, the mounting face would be directly in the middle of the 9.5inches if it was a 18x9.5 ET0 rim. Given it is a +12 rim, the mounting face is 12mm further away from the center (to the outside of the car). Your fronts are +30, so the mounting face is 30mm further away from the center (to the outside of the car). I would wager this doesn't look right, because most skylines generally have the same with guards front to back. So I'd think your fronts look significantly more sunken in than your rears. I'd wager by about 18mm, or so.
    • My '96 r33 Skyline has Rota GTR, 18 x 9.5 inch, ET30 on the front and Rota GTR-D, 18 x 9.5 inch, ET12 on the rear. (Put on by previous owner) The 12mm offset is throwing me for a loop. Is it due to the "deep dish" design of the wheel that the offset it so low? Or is it actually that low on the rear normally? If I were buying a set of new wheels, could I put 30mm offsets on the rear and reasonably expect them to fit? I have GTR Brembos and 370Z rotors (355mm/350mm) if it matters. Thank you.
