Can anyone link me to where to download newer data? I only have the 2001 dataset, and would like some more modern data. Just need A1, A2, A3, B1 and B2.
But for now, can somone please FAST
PV35400829 for me? Any chance of Sewid or someone else who speaks Japanese translate the options for me? Also, is anyone will to translate an auction sheet for me?
Cheers
Feb '93 GT-R, colour code 326 ('Crystal White'), Interior colour 'G', there are pages of data on how to interpret the last few digits of the Model Code, but I got a bit lost!
(KBNR32RXFFS7AA)
But nothing fancy to report.
Hi all,
Could someone be so kind to FAST a VIN for me?
BNR32307816
Supposedly a '94 In GMG.
Cheers
Grant
Yeah it comes up in fast that way.
Model: KBNR32RXFS7AA
Build Date: 03/1994
Color: KH2 (Gun Metal)
Interior Color: G
Nothing else special to report.
Cheers
Send Chook a pm he will be able to help you out as he has the newer version of fast.
Can someone fast BNR32-301013 for me plz?
can some one do mine please
BNR32-303985
cheers
Hi, can someone please help me check up the VIN for this car?
BCNR33002497
Model number GGJPRQFR33ZDAG
Thank you!
Your vin doesnt come up. You might have gotten the numbers wrong but tried the model code too and all it said was invalid model. Might want to recheck your number etc
Thank you very much. does it tell you the engine number that the car came with at all?
just out of curiousity? just want to see if that matches up with original engine.
No fast doesnt give the engine number. sorry mate
Adam,
Thank you.
Yes it's just a GMG BNR32, nothing to see :P
Cheers
Grant
hahaha, R32's are my fav model I was just saying no special features that I could see. I would kill for a late model Gun Metal 32GTR (even better if it was V-Spec II). I have a 32 GTS-T hence the pic but I am a little pissed because it had a respray before I owned it and it was gun metal but I do like the blue just wish I could work out what blue it was.
Hi Baby skyline, thank you for your help. I guess the seller must have given me the wrong VIN number. Decided not to get the car in the end and got a R32 GTR instead. =)
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
