(For some reason I can't edit, this has happened to me before =/)
I downloaded Nissan FAST and installed it all just find just to find out the Nissan FAST setup file is 16-bit, and of course 16-bit got axed in Windows 7 x64. :)
So when I try to run it asks for a CD, does anyone know a way around this?
umm kind of, I got caught by the same thing....thought win64 would be good to try without realising how much doesn't run on it (like flash for instance). anyway, it comes with MS Virtual PC so I installed Win32 on a virtual machine and use that.
Others might know a better way to do it?
hey guys, ive got FAST on a cd, if any one wants it let me know and ill be happy to send it out. for some reason i cant get it to work...
can some one FAST this vin for me please - er33012099
thanks in advance
I installed XP on VMware and got it working. :P
Here we are mate. :)
thanks champ, any info on the transmission???
I would really love to help you right now but not really that good at deciphering the model number yet.
GGKARENR33EDA-----
Essentially should tell you everything.
Hold on a sec I found a way to prove its transmission, it's an Automatic Transmission.
You can tell from the AT and to confirm that I checked the parts and you can see there it's an Automatic Transmission.
I just confirmed with my car (R33 GTS-T) that if it is Manual MT.F5 appears there.
Probably all been explained earlier, but for those who tl;dr.
So your car is an Automatic NA R33 Coupe 2WD in Gun Metal Grey. Not a bad cruise.
Edited by Alinys
GGKARENR33EDA-----
thanks for that... im stumped though as its got three pedals and a manual gear shifter... it must have been converted to manual down the track
here is yours mate
i have another quick question, how can i tell if this gtr i am looking at is a v spec or not? can u find this out on the fast software at all?
i say this because in 2 different adverts, one say its a v spec and the other says its just a gtr? is there an easy way to tell which is which by either numbers on the car or something physical i can look at on the car.
ok, i did a bit more of a search, and came up with this.
on the fast screen shot, where the model number is, if u look at the 6th character along it says Q.
Q = non Vspec
W= V spec
is this correct? if so the one im looking at isnt a v spec.
Hi people,
Im looking at going to Melb this sat to buy the following. Can someone do a VIN check and let me know what comes up.
1996 R33 GTR V-Spec
Model no: ggjprqfr33
VIN: BCNR33002497
Engine No: RB26050285a
Colour code ano K
Thanks
Hi,
Me again, maybe I need to get my arse on installing the software (what file do I need to use for Skylines both chassis no and parts)!
I'd like to find out anything special about this chassis no.
BNR32001945 - Supposedly '89 In black.
Cheers
Grant
As a thread "VIN's you want fasted" was pretty successful so I think we should restart it with some guidelines on what you can do to make it work:
1) Your VIN number is the Vehicle Identification Number from the Japanese factory. It contains your model number followed by the build number of you vehicle.
Examples:
- BNR32001000
- ECR33003928
- BNR34000897
When the car comes to australia the VIN number is prefixed with 6U9000 and you're Australian VIN number becomes 6U9000BNR32001000 (for example).
When posting VIN's all we need is the part of the VIN number after 6U9000.
2) The VIN number is found on the factory blue compliance plate.
3) The FAST program is no longer available for download anywhere as far as I know, is around 2.2gb so I can't just send it to you on MSN (sorry).
4) I do not work for Nissan (sorry again).
Hopefully someone can merge the threads or something....
6u9000bnr32303621 32 GTR DUDE
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
