Here you go guys
Oh, and Nismo Boy, how about you look at how everyone else has provided their VIN and supply me with the correct format - I can't FAST the numbers you have provided. Engine numbers and model numbers are no good.
Hey guys - First post here! Sorry to not give a proper introduction but this request is very urgent :)
Looking at a 180SX at the moment - bit of an epic saga that started in June.
VIN: 6U9000RPS13324593
Engine Number: SR20848988A
Thanks a bunch in advance~ :mrt:
*Corrected VIN number
Edited by Rundle32
Here you go guys
Why i posted the Aussie VIN is past my own common sense, sorry. Here is the correct one I hope.
HCR32-284478
More important than the photo would be looking at the factory build plate rather than the Australian compliance plate. Remember, the FAST system is a Nissan product and has absolutely nothing to do with the local bureaucracy. But in your case, you might want to look your car up on the RAWS site to see what that says too.
The VIN is 6T91MPAAAT1GVT001
I searched through one website and it said it was a blue 33. Which it is. But then it asked to pay so i said pffftttt. Tried searching through other sites and it says that it can't find it.
hey guys i got no idea what happens here but im buyin a r33 gtr not sure if its a vspec could sum1 please help and just anyother general info would be awesome.
BCNR33022988
GGPRQFR33ZDA A AA
the second one is the body num dont know if thats needed, thought id put it neways.
cheers.
The first one is the body number, and the second is the model code. That is the EXACT information that we need in order to look up the car. Others take note!
:D
(But I'm not on a PC with FAST right now, so I can't actually look it up - I'll try to do it later on tonight)
:thumbsup:
you're welcome - but I have no idea how to tell if it is a VSpec or has options - most of the program is in Japanese. Someone else might be able to tell if it is a VSpec from the screenie I posted though?
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
