defari
Mine came up invalid to. (using V3.5)
Whats the model (Under VIN 18 chars, Some "-"'s) VIN's can be "Side steped and verified" with FAST
I suspect the 2249 may be the prob . minez close at 130310, Maybe they don't go that high??
apologies for the shite pics
left pic reads ECR33-132249
right pic reads
E-ECR33
ECR33-132249
engine RB25DET 2498
right pic reads
E-ECR33
ECR33-132249
engine RB25DET 2498
that vin reads ECR-152249 to me
my fast gives a production date of 04/98 but thats it doesnt give any other details
need that GG>>??>>VDA___A of the blue plate
ECR33-014444
I got a feeling my car is a dodgy piece of shit...
**Edit**
Not sure about the rest of the details so i'll put them all down as they are
Blue plate Left to right, Up to down as they are on the plate.
Something. E-ECR33
Chassis No. ECR33-014444
Model. GGKBRTFR33EDA---D-
Paint 1N3
Engine Rb25DE
Something else. FS5W71C RC43
Green Plate (Compliance)
Nissan KT Skyline R33 2DR 1993.
ViN 6T91MPTECPYABG067
Any ideas about the 'KT'?
Also if anyone is immature like me please take note that my Vin has '6T9' haha yay
lol
Edited by Projectile
lol
hahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahaha
hahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahah
ahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahh
ahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahh
ahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahh
ahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahaha
hahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahah
ahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahaha
hhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahaha
hhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahaha
hhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahaha
hahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahah
ahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahaha
hahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhaha
hahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhaha
hahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhaha
hahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahah
ahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahaha
hahahhahahahhahahahhaha :)
just double checked it
its definitely ecr-132249
the gg part reads
GGKBRTFR33VDA----A
March 1997
R33 GTST Type M
Manual
Color field is empty as i believe there is something wrong with your vin.
ECR33-014444
**Edit**
Something. E-ECR33
Paint 1N3
Engine Rb25DE
lol
R33 GTS/S
Non Turbo RB25
Manual
Couldn't get a colour code i think its because its a non turbo... same as the guy a couple of posts above the vin no. won't recognise had to use model number.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
