VINS you want "fasted"
defari
Mine came up invalid to. (using V3.5)
Whats the model (Under VIN 18 chars, Some "-"'s) VIN's can be "Side steped and verified" with FAST
I suspect the 2249 may be the prob . minez close at 130310, Maybe they don't go that high??
apologies for the shite pics
left pic reads ECR33-132249
right pic reads
E-ECR33
ECR33-132249
engine RB25DET 2498
right pic reads
E-ECR33
ECR33-132249
engine RB25DET 2498
that vin reads ECR-152249 to me
my fast gives a production date of 04/98 but thats it doesnt give any other details
need that GG>>??>>VDA___A of the blue plate
ECR33-014444
I got a feeling my car is a dodgy piece of shit...
**Edit**
Not sure about the rest of the details so i'll put them all down as they are
Blue plate Left to right, Up to down as they are on the plate.
Something. E-ECR33
Chassis No. ECR33-014444
Model. GGKBRTFR33EDA---D-
Paint 1N3
Engine Rb25DE
Something else. FS5W71C RC43
Green Plate (Compliance)
Nissan KT Skyline R33 2DR 1993.
ViN 6T91MPTECPYABG067
Any ideas about the 'KT'?
Also if anyone is immature like me please take note that my Vin has '6T9' haha yay
lol
Edited by Projectile
lol
hahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahaha
hahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahah
ahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahh
ahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahh
ahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahh
ahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahaha
hahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahah
ahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahaha
hhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahaha
hhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahaha
hhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahaha
hahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahah
ahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahaha
hahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhaha
hahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhaha
hahhahahahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhaha
hahahahahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahah
ahahahahahahhahahahhahahahhahahahahahahahahahahahhahahahhahahahhahahahahahahahaha
hahahhahahahhahahahhaha :)
just double checked it
its definitely ecr-132249
the gg part reads
GGKBRTFR33VDA----A
March 1997
R33 GTST Type M
Manual
Color field is empty as i believe there is something wrong with your vin.
ECR33-014444
**Edit**
Something. E-ECR33
Paint 1N3
Engine Rb25DE
lol
R33 GTS/S
Non Turbo RB25
Manual
Couldn't get a colour code i think its because its a non turbo... same as the guy a couple of posts above the vin no. won't recognise had to use model number.
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
