could you do mine for me aswell please kind sir
ecr33109237
ecr33109237
could you possibly check my VIN?
vin-ER33-004493
model-BGKARGNR33EDAB
cheeers.
Hmm my version of FAST (v3.5) can't find that VIN or model number. Are you sure they are correct? Could someone else also try and FAST that VIN number too?
hmm thats strange.. i didnt think there were any 1993 4 door r33's.. actually i just realised that cant possibly be my car because the model number is un accurate. anyway for anyone who wants to download Nissan FAST for themselves, i found a good torrent.
http://isohunt.com/torrent_details/9042828...ast?tab=summary
you will need uTorrent or bitorrent & it is about 1.6 gig, seems like its going to take ages to download but it took me like 3 hours roughly.. pretty good. then follow the instructions exactly. and it works great no viruses or anything..
Edited by azzafreddy
it says ER33-004493, but maybe its ECR33-004493? i had a browse through this blog and couldnt find any other R33's with ER before it only R34's..
hey Aaron
this could just be a F up in FAST, I used your model and got the following details, I does tell me the ER33 part IS valid
could you guys check this for me im thinkin of buyin.
BCNR33 004572
GGJPRWFR332DA
thanks
mmmmmm, another V-spec ..... :thumbsup::D
Cheerz
cheers mate, i did the same thing to doesnt make a whole lot of sense tho its all wrong, cars a DET not a DE & i know its a 94' but oh well :thumbsup:
yea FAST gets a bit funny @ times, I've had VIN's that come up invalid, then reboot 'd my PC, and suddenly their valid ????wtf
others that will not work on mr Ver 3.5 but they work on other versions of FAST ?????
weird $h1t...
don't 4get your paint code, interior color and date of manafacture are on the compliance plate anyway,
FAST is mostly 4 looking up part numbers, rather than verifying a car identity though
Cheerz
weird $h1t...
Cheerz
Yeah it sometimes doesn't work, I put in azzafreddy's model number and It returned invalid, although BundyBear was able to get it. Sometimes other people need to try it and it works. Anyway, atleast you got what you wanted now :cool:
hey guys, can i get this checked please.
hcr32-290845.
thanks.
hcr32-290845
yeah for sure, i couldnt do it myself on Nissan FAST v3.5 using the vin number, so i tried typing the vin number and the model number in (model followed by ----, otherwise it wouldnt work) and it came up with the info. its a funny system thats for sure :cool:
What is the number stamped into the firewall? That number most likely is the correct one.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
