VINS you want "fasted"
Also, can anyone lend their assurances that the FAST printout correlates with the compliance/build plate pictures of an R32 I'm looking to buy. Does that compliance plate indicate that it was imported in 2002? And FAST states a gun-metal build colour?
Guy
no one will give you assurances on what is stolen software, this is nissans internal program, and while fairly accurate it DOES contain SOME SMALL faults.
while FAST wiil give details on a cars options (paint color, ABS, A_LSD, etc) it is mainly for looking up part numbers, therefore should not be relied on souley
as for compliance plates, Blue = orig nissan plate (note the 6U9000 is missing..) green is the australian import plate
given FAST and nissans plate list the same paint color, I'd guess thats the original color
Car passed compliance 08/2002 (Green Plate) and therefore was imported before this date (usually only weeks B4 but could have been anytime)
cheers
im trying to get a full list of options which came on my car
could someone check
ECR33105178
please :happy:
Anf
sorry man only lists ABS and a lot of jap my pc cand handle
you might have betta luck HERE
cheers Bundy
Cheers mate, I understands what your saying, I probably should has used another world rather than "assured", I was merely looking to confirm I was using the software correctly. It could come in handy later if I end owning the car (provided the StateRoads inspection goes well :D), the fact that the plates and the read-out correlate is a bonus.
007589a guys this is the engine number of the motor i will be looking at tommorow. could i please get a back ground check of this motor and is it a nismo motor??? thanks much appreciated.
Hi guys, would you be able to check these 2 VIN numbers
1. 1995 R33 GTR V-Spec - 6U900BCNR33005989
2. R32 GTR - 6U9000BNR32002902
I am looking at purchasing either of these vehicles so I want to confirm they are both GTR's and what factory options the vehicles came with etc.
Cheers for the help!
Jace
Jace
There you go pal.
I remember finding a good page that had the meaning of all the codes. I will try and find it and post it up.
Here's the VIN # for the Midnight Purple R33 GTR V-Spec 1996.
6R91MPORTWH2R1001.
I know this seems like a strange VIN #, however where I work we record all VIN #'s, and this is what is on our records for an immaculate R33 GTR I'm considering buying. My assumption is that this VIN # was issued by South Australian Licensing Authorities (that's where it was imported to).
Would be appreciated if you could check it for me!
Cheers,
Jace.
Could i get this VIN number checked please - 6U9000BCNR33024253.
I gave you the Australian VIN number for this car in my last post, which you advised would not be recorded as it is not a genuine Nissan VIN.
The genuine Nissan VIN is BCNR33024253, however I placed "6U9000" before it.
Hopefully it is recorded on the fast software, and it should be a 1996 R33 GTR V-Spec Midnight Purple.
Cheers!
    • So I've been working on the car a fair bit, doing a lot of little things.  Still making slight adjustments to my tune, as the cold weather settles in. I've also had to start dropping boost and tire pressure as the weather gets cooler. It's getting very swirly at highway speeds. I drop to 20psi at 20C and 18psi spring pressure at 10C IAT's. I'm currently on 255 Falcon RT660's, but may look into running 275's next summer. They will fit, but barely. Might have to raise the rear a tad.  I'll start redoing my exhaust Monday, as I have the week off. I currently have an oval center muffler and cannon rear muffler. I've been told more then once from people behind me that my rear bumper is going to catch on fire one day. Seems I blow 5-10 second flames after doing a pull. No clue if that's the WMI, as I've never been able to do that before with other cars. I wanted to angle my tip down a tad so flames are pointed down and away from bumper. I also wanted to take the opportunity to reconfigure my exhaust line. I'm going to move my oval muffler to the rear with a pie cut angled tip and put in a new smaller round muffler in the center. I've rocked cannon mufflers on this car for the last few years and want to transition back the oval muffler look. I've also been looking for a stainless project to try out the new solar flux I bought. I'll post pictures on Monday, should be able to wrap that up in a day.  I'm also picking up another rear subframe this week. I wanted a second so that I could modify one with a gk tech anti squat reduction kit during the winter, and still be able to keep the car a roller so I can back it out of the garage if needed. I will also be caging it this winter. More on that later. Lastly, Speedtek still hasn't given me diddly squat. Every week for the last 4 weeks, they have been saying next week. They told me Friday to expect a shipping label that day to ship my two bad sets of ring and pinions back and nothing. There's definitely been more contact since I started destroying their company any chance I get on Facebook, but it's still just words without action.
    • Have you done a pressure test on your intake/piping? Cleaned your IACV and Cold start valve?
    • Bit of a dump of ones I saw on my trip. I also have a heap from daikoko but that’s technically not  on the street
    • i was thinking that the 2 wires that go to the sub from factory has some sort of preamp like you mentioned and also a lo Pass filter to get just bass. now that will only use 1 channel and that really should be all i need for a sub? if i was trying to put a set of speakers in the back i can understand cutting into the left and right speaker wires. i will try how im talking about doing it and if that is crap i will do it the way of all wires. thanks for the input guys.
    • Challenging mig welding thin Aluminium pipe and trying to fit it in, having to bend and twist, but got there in the end. Fits really well and can easily get a socket wrench in there now to put it on/off. I'm in the middle of another project, so haven't installed the suction pipe yet. I'll post some pictures and results when i do.
