VINS you want "fasted"
the number format looks correct, but this is what FAST (at least my copy) says:
Now that's strange...I wonder what's the story behind this? :devil: Anyway, thanks for the help Gaspard!
Can you find a Model Code off your car?
as that can be entered first then the rest of the VIN can be added.
Cause that's how it worked to find out all the details for my R30.
Socrates.
hey guys, was hoping someone could do a few screenshots showing the balance pipe between the turbos on a GTR. ie: the recircualtion pipe that goes between the inlet elbows.
please use VIN 6U900BCNR33003083 or any generic R33 GTR VIN.
cheers, Nige.
I put model code in first then the rest of the VIN
July 1983
Can the japanese be copied into google translate?
not directly but I'd been matching it by hand yesterday...
(i got my FAST to display actual Japanese Characters)
The first one is Body type, which when using google translate on the jap returns "Boday" (so I assume the guest translator is a bad speller, or English FAST has someone in Japanese "sounding out" the words)
The second one literally tranlates to "Engine" so that's the engine code... I assume L20T is Turbo version
Grade (option trim level)
and Transmission... FA = Floor action auto...
I will now post what little translation I did on the option code lists:
It is very slow tedious work doing this, if someone had a Japanese friend it would go much quicker...
I'm literally using Character Map, autohotkey's window spy, and my naked eye to match the shape of the ideogram, then copy into google translate...
translation I did last night:
ボデイ -- Boday (aka Body type)
エンジン -- Engine
グレード -- Grade
ミッション -- Transmission
ステージア -- Stagea
Edited by Gaspard
cheers, Nige.
On to it...
I just tried but my FAST now has runtime error 13 when viewing diagrams... so maybe my attempted semi japanese mode is screwing it up... will try again after changing a few things and report back..
EDIT: Fixed my runtime error
Here are the diagrams:
1. Exhaust section:
2. Turbo section
(The turbo has 2 other diagrams for cooling, and oil lines, figured you didn't want them.)
3. Part numbers
(After selecting the 2 dump pipes and the exhaust header, and click "Part No. Search")
EDIT 2: Actually reading your post would help eh!
LOL after re-reading your post I noticed you said "inlet elbows"
So you're after the INLET sections... DOH!
One moment please...
EDIT 3: ok so I looked through the inlet diagrams:
Hopefully one of these helps?
Edited by Gaspard
built 01/05
r34 2.5gtt
colour: TV2
i will upload screen shot soon for you
Can someone help with uploading
i cant seem to do it right.
Thanx
One more favour please?
I'm after screen shots showing the intake tract on a 33GTR.
I need diagrams of the squishy intake pipe, airbox, AFMs, etc. whatever you can find.
cheers, Nige.
cheers, Nige.
anyone please?
anyone please?
PM'ed.
Can I please get this vin checked
bnr34-401570
thankyou
bnr34-401570
Could i have ecr33017606 and ecr33017083 FASTED please.
Thanks
ecr33017606
ecr33017083
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
