Dont know, it wouldnt come up with the vin number, so i put the model number in, then it asked for the vin, put that in and thats what came up.
Yeah right...
Hah!
So Mohsen's R32 has a carburetor then... :(
Hey guys dont know if nissan fast will confirm this is a tommy kaira GTST but its worth a try..
VIN is HCR32-084252
Thanks in advance
yea nothing special shown in fast. pretty sure the likes of tommy kaira, mines etc worked their magic after nissan spat them out the factory. unlike v-specs, n1s, nurs and m-specs which were all built to be that right from the start
Hi all,
I'm trying to determine if mine is a series 2 or has had bits bolted on. (can't get fog lamps to go on plus a couple of other things).
04/1996 R33 GTS-t.
Wondering if the FAST will show for sure.
Chassis # ECR33-107207
Model # GGKBRTFR33VDAEALAC
Cheers!
Edited by awhiteone
Hi all,
04/1996 R33 GTS-t.
Cheers!
According to wikipedia, the series 2 33s started in 1996 and yours is confirmed a 96 model. The series 2 also have driver and passenger air bags, do you have them?
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
