Hey guys,
I'd really appreciate it if someone could do a check on this 1997 R33 V-Spec that I'm buying:
BCNR33-023728
Thanks folks. Hope its a Spark Silver V-Spec.
Regards,
Loki
Edited by Jebat
Hi - could someone run this one for me pls.
6U90000NM35311559
Out in the bush with rip off internet so the FAST download is a bit big!
Cheers :no:
sorry M35 isnt in my fast, someone out there may have a more up to date version
Hey guys,
BCNR33-023728
Regards,
Loki
vspec: computer says no..
Doh k. Thanks for checking for me, mate.
The odd thing is:
1. I looked underneath and the rear diff had fins on the cover.
2. Not to mention the original speedometer on the car has the A-LSD sign.
WEIRD!
I was hoping it would be a V-Spec but I guess its just a normal GTR. Will miss out on these goodies :no: -
"The V-spec model weighed in 10 kg (22 lb) heavier, and had sportier suspension resulting in lower ground clearance. The V-spec also featured the newer ATTESA E-TS Pro all wheel drive system, which included an Active Limited Slip differential. The V-spec model also included a four wheel independent channel anti-lock braking system".
Edited by Jebat
can i get this one checked out?
This is all the numbers in order from top to bottom of the compliance plate.
What do the non vin numbers stand for?
E-BNR32
BNR32-100429
KBNR32RXFSL RA
KH2 G
RB26DETT
FS5R30A RC41
5
Hey guys looking to confirm that this is an R32 GTR VSPEC...
BNR32-000598
Fingers crossed.
Thanks in advance..
i ran this one through fast for someone else in early september, been on the market for a while?
anyway.. not a vspec. im pretty sure vspec only appeared from late 1991?
Edited by jonboy
E-BNR32 = 2.6ltr, super hicas + attessa, r32 model.
BNR32-100429 = build number
KBNR32RXFSL RA = model specifics and option codes. wont go into detail now
KH2 G = colour. KH2 is gunmetal grey metallic. i believe G is probably interior, grey.
RB26DETT = engine
FS5R30A RC41 = transmission + final drive/diff ratio. several different FS5R30A gearboxes exist.
5 = manufacturing plant location, thanks to socrates below for correction
Edited by jonboy
