VINS you want "fasted"
BNR32 013343
thanks in advance.
this will be interesting. the compliance plate that the aus government put on states as 8/93, which should be series 2.
dont have the brakes, has push clutch.
and the vin plate also has the 6U9... doesnt end with the factory vin.
I'm sitting here with the start of the flue today, so thought I'd reinstall fast (Haven't run it for years) and help out a few of these...
6U9000BNR32007072 - R32, made march 1990, color kh2, GT-R manual, model KBNR32RXFSLMZG
BNR32013343 - R32, made December 1990 (so definitely not 1993!), color kh2, GT-R manual, model KBNR32RXFSLMZG
6U900BCNR33004065 - R33 GTR/V, made March 1995, color LP2, model GGJPRWFR33ZDA-----
6U9000HNR32036867 - R32 GTS-4, manual 5 speed, rb20det engine, made may 1993, color 732, 4wd, model KRNR32RGFSLCA
DR30 036466 - R30 made sept 1983, color 060, and "F5" is coming up where the model normally is. I think the engine is FJ20T
Hope that helps everyone.. :-)
Edited by ian
JN1WRGY60A0046947
Cheers jnr
I tried a few different combinations(it is entered in two fields ie BNR32013343 is "BNR32" and "013343") ie
JN1WRGY60A 0046947
JN1WRGY60 A0046947
WRGY60A 0046947
WRGY60 A0046947
And it can't find anything. And it isn't the build date either, as though my copy of fast is a bit old it has our feb 2001 stagea in it (Looking at the list it has I have data up to about July 2001) and it definitely goes back to the 80's...
So I'm not sure what I'm doing wrong....
Ian
Chassis No: ECR33-130626
Production date Feb 1997, KR4 color, HICAS, RWD, Manual 5 speed, model GGKBRTFR33VDA----A, and it's a GTS25T
- and I don't know how to bring up the 'options' page that a few other people have posted - can anyone tell me how to?
Ian
    • Hello again, I just want to tell you that i found the reason why my bnr32 is going out in right corners. I had my car tuned by a company and they fitted the Emu Classic and a new fuel pump in 2021. I checked the loom, changed the walbro fuel pump with a Deatschwerks fuel pump. None of this helped. Then I checked the fuel pressure and thought I was crazy. It was tuned with over 7 bar ( over 100psi) !!! But why? So I checked the fuel return line and saw that it was closed. That was probably also the reason why the tuner replaced the fuel pump, but he tuned the Emu with the 7 bar 🫣 The map in the emu has now been changed and evertyhing is fine.
    • I'm going to vote for considering going to the effort to close the lash down to the minimum. My bro-in-law got around to checking the clearances on the 3SGE in his Caldina. Was a bit fat all over. New shims at lowest allowable lash, and the car is remarkably better to drive. It appears that the increase in both total lift and duration that you get from doing this is worth a lot more than you might expect. I have been having evil (and expensive and time consuming) thoughts about doing it to mine, and I don't even think I have a problem. Not that I'd know, though.
    • Thanks for that, it actually sounds fine to me. What oil weight are you running and what kind of oil pressure do you see around idle RPM and a bit over it?
    • https://youtu.be/CCHaKUhZi34?si=PNdluupk9TWFtvws
    • Maybe record a video and post it up on YouTube and link it back here
