VINS you want "fasted"
Ok so is this correct for model number RNR32GASLMDB
R = RB20DET
N = 4WD with Super HICAS
R32
G = GTS-4
A = 4 Speed Automatic
S = Intercooler + Turbo Type
L = Projector Headlight
M = P + Q ~ P = Electronic control active Full auto air-conditioner (Climate control system I assume) - Q = Electronic control active Sound System (Upgraded Sound System?)
D = GT Auto Spoiler (Front Only) Viscous LSD
B = 4 Wheel Anti Skid (ABS?) GTR Steering Wheel
Edited by Aljo
Can someone please run my vin for me. It is 6U900BCNR33003151.
As far as I am aware its a 1995 series 1 R33 GTR. However I have just put it in for some mods and the tuner said 'he did not realise it was a V-spec'.
Niether did I. I dont think it is.
The absence of a "V" doesn't look promising
Hey, i own a R32 skyline and need a roadworthy asap to register it. It has 2 plates in engine bay one is the nissan plate but has no built date. The other is the mod plate but still doesnt have a built date/ month. Only has a code L01. My vin is HR32001950 any help to get the built date/ monthwould be greatly appreciated!
    • Hey team,  The clutch on my newly bought 25 swapped r32 feels average and sticks half way. Went to go order a new clutch master but it does not look like the ones that suit the one that’s in the car…    does anyone know what clutch master is this just by looking ?  (The feed is on the side rather than the bottom like the ones the pop up online)  thanks guys new to the RB scene so any help is appreciated cheers !!
    • Id be more than happy to sign up!!! Where do I send the invoices for my fuel usage? I'm happy to provide the mower, oil, and the labour to abuse the motor, just a little help on fuel would be great...   I had tipped the container of oil out into my big "drip tray" and left the small container upside down to drain the oil out of itself overnight. PIcked the container up today, and it has a layer of what feels like either dirt, or shit tonnes of carbon in the bottom of the container. I'm leaning towards it likely being dust, as I doubt the quality of the Sunli BumbleBee having a decent air filter on it, and sections of my yard produce a dust storm, especially because of the high lift blade!   So, filled her up with some fresh Nulon. Seemed to run fine, but it seems to want to run at really high RPM (higher than normal) even with the governor spring slacked off after fire up to try reduce it. If I back the throttle off it a bit to drop the rpm to where I'd like it to be when mowing light grass, it starts to blow a bit of smoke out the exhaust. Opening the throttle back up clears that out. It's definitely breathing oil, as I put my hand down at the breather hose and it's spitting some oil.   My guess is it having been running at high rpm, oil never changed, and it eating dust has destroyed the rings. You know what that means? Time to send it!!!
    • That is what will seal with the bonnet closed. Follow it down while closing the bonnet to see where it ends up with the bonnet closed. The panels don't do anything other than spending money, which this one will do just fine. :p
    • Nah just send me a photo or a drawing and I'll tell you which is better.  It's a new SAU service.
    • Yes, well, one or the other. On R32 (which is the only thing I can look at personally) it's on the rad support panel. You have neither, and it will need to be on one or the other. I must say that the arrangement of holes perhaps looks more like it lives on the bonnet underside on the R34. The rad support panel doesn't look like the R32 one at all. A quick google shows....
