What are your thoughts on using the red Permatex stuff? My rocker cover uses that and I didn't want to mix it incase it causes problems. Or maybe I'm overthinking it.
Does anyone know when removing the throttle body if you can re use the throttle body gasket?
Is the suspension at full droop? Try pushing up the lower arm with a jack. Careful not to lift the car off the chassis stands.
OK well I might narrow my search a bit then based on that. So your bearings from JustJap, did you use the existing hubs and press the old bearings out? Front ones I assume. I have my own bearing press, a small 12t one and I pressed my own new bearings and hubs for the rear, pretty easy but as they were new parts they weren't rusty like the ones I removed. I saw a Z1 370 rear upgrade kit, on my list for future upgrade.
