Diff =/= Final Drive.
Final drive ratios for All 32 GTST's manual or auto are the same as R33 Auto Ratio (4.3:1) Manual 33 GTST's run a 4:1:1 final drive ratio.
The differential bolts inside of the crownwheel(Parts of the final drive) and this gives you your LSD. When you buy a Nismo LSD kit you will not get a new final drive crown and pinion so your ratio will stay the same.
Well there ya go, cheers mate :thumbsup:
Hello!
Would greatly appreciate some help. I think this is the correct VIN. (hopefully)
The car is imported from Britain to Sweden. I don't know if that information is needed.
#WGNC34018235
Cheers guys!
Edited by Miltuun
Thanks for that! does this program do anything else? or just provide those details?
Can provide part numbers and Model Options. Miguelone can translate better than I can.
WGNC34129431 Please. Thank you very much in advance!
Wow! It's a regular Stag Fest lately. :D
Edited by Not a Pulsar
Hah yeah I saw another Stagea member post it in the stag section and he got directed to here so I thought, why not !
I had trouble with fast before as I run win764bit. Now have just found fast 2010 64bit compatible here - http://club-s12.org/retro4/index.php?topic=32213.0
download will be finished in 4 mins
Thanks for the quick response!
Nice one. Ima needing a more recent 32bit version. :(
I am not sure if I misunderstand you. Are you saying that it won't work for you ? It's 32 and 64bit compatible incase you thought it was only 64bit.
Sorry if I misunderstood. It's the sad smiley that has me all confused :D
More recent US version using older Jap files will be the same as using the older version though. Have a look around for the 2009 Jap version for the catalogues and use the current english version program. Works the best.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
