VINS you want "fasted"
Hey guys... Would be highly appreciated if someone could check the following for me
6U90000ER34026311
My 34r has being FASTED before but i would like to know what, if any, options it possibly has listed in FAST
BNR34004509
Thanks
I checked my system but no options came up...
Check with Michael and see what he gets.
This one please when somebody has time.
  • BNR340060706
    Thank you in advance.
Thank you a bunch for the above... Appreciate it. I have another if you're willing to check and post back.
6T91MPAAASYAXZ002 or if that doesn't work then ECR33023224
No matches, check numbers again please.
bcnr33021039
Sometimes it happens. Not often since I've sorted all my catalogues out properly but it still does occasionally. I guess the biggest issue is probably just that these are all ripped catalogues, they're not updated or maintained by Nissan like the dealers system is.
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
