May i have bnr32-017857 decoded?
Can't edit my post, i think the number is actually bnr32-047857, not 017857...
Both those numbers had complications.
Post a pic of you build plate and let us have a look.
Well that's the problem, it's not on my plate it's on the engine. I know my chassis is a 1993, i can still post a pic, but supposedly the stealership i bought it from here in Okinawa said it has a newer, but lower mileage engine in it, not the factory one (not sure what happened to it). So newer would mean to me 93+ model year engine. But i have reason to believe it's in fact NOT newer, so I'm a bit curious. I'll see if i can get better look at the numbers, had my wife look at it and she said it looks like the first number I posted, 017857. So i dunno.... :( Edited by Silverstreek
Well after further looking into both the VIN's you posted, they both came up as (July) 07 / 1991 models...
Wouldn't surprise me about the engine swap, it happens in Japan...
Still post a pic of the VIN's and lets have a look.
Also, do you have the VIN engraved on the firewall?
Yes i do and it matches the blue plate, so that's good. They informed me before and after I bought it, the info about the motor, so i knew it wasn't the original. But, like I said, they said it was "newer" AND "lower mileage". On the paperwork i got with the car it says "used engine ". So, I'm guessing if I tried to take it back and tell them i want my money back and to cram this car, I'd have no ground to stand on. Le sigh....
I see, thanks for that.
How many Km's has your GTR done (Speedo) VS the amount of Km's the "Used Engine" has done..?
Do you know if the timing belt has been changed?
Any stickers..?
Hi can someone please check, bnr32-309201
Thank you.
Kbnr32rxf7s aa
Thanks skyline.
Ok thanks!
The complications came up with a few results, one saying it was a Base Model and the other saying it's a V-Spec II.
But you Model Number confirms it to be a base model R32 GTR, built in March 1994.
Damn, can we go with the vspec II. :)
Thanks mate love you work.
I was checking cause I pulled motor out for rebuild and it has short nose crank so obviously not original motor.
:laugh:
It's just Brembo calipers that make the difference, along with a sticker and BBS Wheels for a V-Spec.
Not original engine or had the RB26 been modified from previous owner?
    • No not yet.  Hopefully this weekend if I can pluck up the confidence!  I had to sit in the car at one point yesterday to unbolt the rear struts.  As mentioned in an earlier post when I was putting it together there is still a bit of rotation possible so when I sat in the car, it rotated a little bit.  I near shit myself thinking the whole thing was coming down!  I do 99% of my own shit in the shed but I think I might call on some assistance the first time I spin it!
    • Strong first post. On a Skyline-centric forum. Have you considered actually going out into the world, visiting the actual dealership, and asking the parts guy over the counter? Or at least just call them up on the phone?
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
