9 hours ago, wiz.au said:
It's that to source parts properly in FAST, including trims and colours, he only uses FULL VIN & 'Model Code'. This ensures the correct part is filtered/selected out and displayed. Dont know why, just using the partial VIN doesnt do that. It gives you a list of options and you have to work out which one you need. So we have both been used to using the full VIN & Model code for part searches.
Yeah sometimes you get options using the short code, but it will say RB20, or 4 door etc and you just choose the correct one and you get the right part. If you put the model code you get the options for rear wiper, airbags, stereo etc too. Trim and colour has always been 100% correct with the short code. Give it a go in gtr-registry =-]
  • 1 month later...
  • 3 months later...
  • 1 month later...
It's a 260RS in KR4 Sonic Silver with a rear spoiler.
Production number is 260RS (Series 1.5) #842/986; 260RS #842/1734
http://gtr-registry.com/en-wgnc34-vin-table.php
Edited by sin-
  • 4 weeks later...
  • 3 weeks later...
More as an option, you can also look VIN up on the following site which I tend to use in conjunction with FAST.
https://nissan.epc-data.com/ - just put in the model # into the search box e.g. WGNC34-103359
https://nissan.epc-data.com/stagea/wgnc34/286-rb26dett/?frame_no=WGNC34-103359&ref=
The EPC online has been around forever but Mark made this more recently: (https://www.sau.com.au/forums/profile/95792-sin/)
http://gtr-registry.com/ choose car, then vin table.
  • 1 month later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
