9 hours ago, wiz.au said:
It's that to source parts properly in FAST, including trims and colours, he only uses FULL VIN & 'Model Code'. This ensures the correct part is filtered/selected out and displayed. Dont know why, just using the partial VIN doesnt do that. It gives you a list of options and you have to work out which one you need. So we have both been used to using the full VIN & Model code for part searches.
Yeah sometimes you get options using the short code, but it will say RB20, or 4 door etc and you just choose the correct one and you get the right part. If you put the model code you get the options for rear wiper, airbags, stereo etc too. Trim and colour has always been 100% correct with the short code. Give it a go in gtr-registry =-]
  • 1 month later...
  • 3 months later...
  • 1 month later...
It's a 260RS in KR4 Sonic Silver with a rear spoiler.
Production number is 260RS (Series 1.5) #842/986; 260RS #842/1734
http://gtr-registry.com/en-wgnc34-vin-table.php
Edited by sin-
  • 4 weeks later...
  • 3 weeks later...
More as an option, you can also look VIN up on the following site which I tend to use in conjunction with FAST.
https://nissan.epc-data.com/ - just put in the model # into the search box e.g. WGNC34-103359
https://nissan.epc-data.com/stagea/wgnc34/286-rb26dett/?frame_no=WGNC34-103359&ref=
The EPC online has been around forever but Mark made this more recently: (https://www.sau.com.au/forums/profile/95792-sin/)
http://gtr-registry.com/ choose car, then vin table.
  • 1 month later...
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
