quick question -
I've always been a bit suspicious about my car. When mine was done through fast it came up invalid paint code - lanky said it may be a problem with the VIN - everything else matches up.
Could it be a possibility that the car is dodgy? have had no problems registering it (was previously in nsw) police have pulled me over mutiple times so im leaning towards it just could be a problem with FAST? surely if the car was dodgy they would've picked up on this when it was registered by the previous owner in qld and by myself when I bought the car. + also police would've been onto it right?
  defari said:
quick question -
Yeah sometimes FAST isn't 100% accurate and can make errors, it won't even find certain VINs. Maybe a later version would be more accurate, but I dunno.
  ReflextioN said:
Got the R32 and R34 but not the R33, double check the vin?
Thanks for that mate.
Whats the vin of any R33 GTR?
I know that my one was the 102nd.
I'll check it today and post it if noone knows.
You want just a random R33 GTR VIN?
This is from one I did before.
Hi could you check this...
Advertised as 1993 GTR with std drk grey paint.
Body
BNR32 - 300387
VIN
6T91MPAAAP1BAE007 (on green plate and a separate long narrow stamped plate riveted to fire wall)
No BLUE build plate only a GREEN import/compliance Aust Std 1989 plate....imported 06/01
GREEN Plate is attached where BLUE build plate should be or was...
Any help would be greatly appreciated. A little confused as to why the BLUE build plate is missing or has been removed...
Cool & thanks advance
Body
BNR32 - 300387
VIN
That is the VIN and heres the pic:
Although the paint code for gun grey metallic is KH2. KL0 is spark silver metallic.
Edited by Dark26
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
