thank you doodz.
merry christmas and merry christmas to SAU.
already opened my presents.
:P
EDIT: what does the 2k mean?
so this is a 6/95 GTST counts as a 1.5?
thanks
:D
2k I think apparently means 2 door coupe (Deciphered a few pages ago http://www.skylinesaustralia.com/forums/in...96&st=200#).
Unless someone can read the japanese text.. and tell us? Beer Baron?
Read through: http://www.skylinesaustralia.com/forums/in...showtopic=17349 it has some info on S 1.5's
if anyone gets time could i get
6T91MPAAAKYANR002 - yeah thats what the VIN plate says on the S13 (its ok to get the S13 checked? :P)
we had a similar toyota version to FAST at toyota. at the parts department.
thanks in advance
mark.
Edited by markimak
6T911MPAAAKYANR002 - yeah thats what the VIN plate says on the S13 (its ok to get the S13 checked? :P)
thanks in advance
mark.
Invalid model number.
Do you know the VIN?
Should be something like S13xxxxx I think
