also - does this vin number mean anything as it is associated to the above chassis number:
6T91MPAAAR1BCW004
im not sure why the same car has a different vin number & different chassis number...anyone know why this might be the case?
  On 03/01/2011 at 10:21 AM, miguelegant said:
The top number is its JDM vin it would have come with from the factory, the lower VIN is the one it would have been issued with during compliance for registration in Australia.
that is interesting as 2 other gtr's ive owned never had a different vin for aust registration purposes
Hmm, I was just assuming as it looks similar to the Aus vin my 33 has from compliance. It may depend on when/where it was complied or a whole bunch of other reasons so if someone with more knowledge on the subject could chime in that would be good.
  On 05/01/2011 at 10:49 AM, Blizzerd said:
wgnc34-125532
Can you tell me what computer this came with originally?
need to know if its a 0v800 or 0v801
Thank you
That car was originally fitted with a 23710-0V800. (Later models used the 23710-0V801)
  • Like 1
  On 12/01/2011 at 10:25 PM, overd0se said:
6U900BCNR33006132 please
Hope this works......
Can anyone point me in the right direction for working out the options from the model number, The R32 Im looking at has this model number KBNR32RXFSLMZG
Edited by Bren81
Top right of the screen where all the buttons are there is a white and blue one that says OP. Click it for options fitted to vehicle. A lot of older vehicles will show jibberish... newer ones will be in engrish.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
