Top right of the screen where all the buttons are there is a white and blue one that says OP. Click it for options fitted to vehicle. A lot of older vehicles will show jibberish... newer ones will be in engrish.
Thanks Psymon, just comes up with lots of pages of Japanese.
Bis-e Bee - That VIN doesn't work in my version of FAST, but I think my data might be fairly old and may not have stags in it. Either that or Im doing something wrong. Im new to all this.
You're probably doing it right, the versions of FAST floating around on the internet are fairly dated and seem to be missing a lot of VIN data. I work for Nissan so my version of FAST gets regular updates.
Someone please FAST this one for me, I am running 64bit windows and cannot get it installed :(
NM35318296
See attachment.
See attachment.
Thanks Psymon, much appreciated. Could I also trouble you to do an options screen shot?
This one was supposedly factory fitted with "some" Nismo options, just wondering if that is genuine.
It's currently got Nismo wheels, bodykit (including rear wing), Momo steering wheel, I assume suspension too but havn't had that closer look yet.
Thanks again!
Hi all,
could someone run these part numbers in FAST and see what it comes up as (if at all)
nissan part#
98584 77F00
98584 26U00
98584 20U00
one of them hopefully should be an srs aibag module for a type x 180sx... But not having much luck so far..
Cheers guys
Edited by Yeedogga
Hi all,
nissan part#
98584 77F00
98584 26U00
98584 20U00
Cheers guys
None of those numbers worked for me. Had a quick look and there's 3 numbers for drivers airbag module to suit a type x 180sx. If you can grab me a VIN from it I can narrow it down.
Sheeeit, how do I google translate a PDF?
Well I uploaded it to this site that converts it to text so it will be easy to run through google translate easily. I'll post the link up here when it's done.
Edit: Hmm didn't end up working how I'd wanted, back to square one :(.
Edited by miguelegant
Probably better off finding the ones that correspond to your VIN and just translating those few lines rather than having a crack at 8 pages.
There should only be 4 lines that apply for each model code.
Edited by Psymon
Characters 14 - 18 (in your case HCDBA). I got really bored so i did yours.
16 Inch Aluminium Wheels
Sports Rear something (kept translating as interface or boiler... maybe spoiler??)
Sports Seats (i think) + GTS25T(more jibberish)
something about Stereo Components
Passenger Airbag
Here is the original 5 descriptions if anyone wants a crack at translating better. Not sure if the forums will display japanese characters though.
16インチアルミホイール
リヤワイパー+リヤスポイラー
ポーツシート+GTS25タイプS/S(4ドア)
コンビステレオ
助手席エアバッグ
Edited by Psymon
Sports Rear something (kept translating as interface or boiler... maybe spoiler??) Would probably be spoiler as it has one.
Sports Seats (i think) + GTS25T(more jibberish) It's a non turbo so I dunno.
Passenger Airbag Yeah
16インチアルミホイール
リヤワイパー+リヤスポイラー
コンビステレオ
助手席エアバッグ
Cheers.
