QWK32 thank you, I am grateful!! Now to interpret....hrmm
i'm not 100% on what everything means but i can tell you that the car is a
R32 GTR, 5sp Manual, HICAS, 4WD, that was made in September 1994
i think the colour code 326 means its a white car and the interior colour "G" i don't know. i also cant remember what the "2K" means sorry.
Thanks again QWK32. The 7AA and 2K are confusing me still. At least the rest checks out so far though! On with the test drive and vehicle inspection...
7AA and 2K anyone?!
7AA and 2K anyone?!
just remembered, i think the "2K" means its a 2 door. 4 door shows up as something like "4K". i'll see if i can check what the 7AA is, there is a model code break down in fast, give me a sec thumbsup.gif
edit: sorry mate, i cant make sense of the model code breakdown for the "7AA" bit. the rest of it i can, just not that last bit.
Edited by QWK32
here mate, cant see any factory options fitted.
Cool, much appreciated. Very interesting given I know it at least has the Dayz carbon dash inserts and seems to have a few other bits and pieces.
i think you'll find that DAYZ options are fitted after factory. they are a dealer fitted, but nissan approved, option. search the stagea section for the DAYZ threads, plenty of info floating around. if you cant find the threads with the brochures pics let me know and i'll dig up the copies i have saved, they are interesting to have a look at.
Edited by QWK32
Hmmm, that's interesting in itself, I always assumed they were factory options. I'll do some searching. Thanks!
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
