Ok thankyou very much really really needed that and appreciate it. Would anyone be able to decifer what everything means. I can understand the basics but not all of it, Can i tell if my car is a genuine series 3 from this
Built date is March 1997 (not sure when S3 started in R33), its white and i think K is a grey interior.
Looks like there's some options on it (15th 16th and 18th letters in option code). I posted a PDF a page or so back that you can use to check the options but you'll need to translate from Japanese.
Hey my mate has a rather unusual VIN, i thought it looked a bit different to the normal nissan style, if someone could fast it it would be much appreciated :)
6P91MPORTRHJ28109
I thought they had car model in them example ECR33 so and so fourth?
Thanks guys
6P91MPORTRHJ28109
Thanks guys
Grab the one off the blue plate on your firewall not the green plate/ wherever it's stamped.
