  On 09/08/2011 at 3:15 AM, blur said:
Nice, a real Vspec 2 N1.
Is that what the ".17" means on the end? Someone else asked this question earlier and I didn't have a good answer other than "it's not a regular GTR." =-o
  On 12/08/2011 at 5:48 AM, mikeyR33-T said:
hope someone can help just purchased an r33 and it has two plates, blue and green, and a silver plate in the middle with the VIN
the numbers i have from the jap blue plate is ECR33-016380
hope thats enough info?
Correct information (as per my signature), but the VIN seems to be invalid. It would appear to be a series 1 (early ) number, but perhaps there is a digit incorrect there?
I changed the last digit (0) to an "8" incase that's the mixup, and it is a valid number.
The .17 means GT-R with 17 inch wheels aka Vspec.
The model number ends in ZN which is N1.
Stupidly rare car, has been auctioned in Japan twice in the last 6 months.
hi, incorrect my car is 2door, is automatic, is skyline r33, it has hicas, the vin says ECR33-016380 - checked a few times.
then the green vin starts with 6E91xxxxxxxx05053
the plate also has written under the ECR33
GGKBRNTNR33EDAA
KH2 K
RB25DE
AGAIN I AM CONFUSED.
Ah yes, bigger wheels for sure... I get that now. N1 is the Nismo enhanced version, and we can deduce that it's a VSpecII because they were introduced in 1994?
Wiki:
  Quote
To celebrate the success of the GT-R in both Group N and Group A racing, Nissan introduced the Skyline GT-R V-Spec ("Victory SPECification") car on February 3, 1993. The V-Spec added Brembo brakes and a retuned ATTESA E-TS system to the Nismo and N1 packages, as well as 17" BBS wheels with 225/45/17 tires. The V-Spec has a list price of ¥5,260,000.
Finally on February 14, 1994 the Skyline GT-R V-Spec II was released, with the only change being wider 245/45/17 tires. In addition, both the V-Spec and V-Spec II had a curb weight of 1,480 kg (3,256 lbs), weighing 50 kg (110 lbs) more than the standard GT-R.[11] Total production of the V-Spec I and II was 1,453 and 1,303 units respectively.
Oh wow... that *is* rare! haha!
GGKBRNTNR33EDAA
KH2 K
RB25DE
Well, I don't want to tell you that it's fake VIN or a grey import or anything like that, but i've not come across any VIN that hasn't populated in the software.
The model should work but even that does not. I know there are 100 R32's that were locally delivered, but to my knowledge no R33's were ever locally delivered... so I would expect that as a Japanese R33, it should be in this Japanese database.
Could you take a picture of the plate?
hi,
I have registration papers with that 6E91 vin number, I have now taken photos of the vin from japan, and it definitely says ECR33, could it be the GTS4 it is the RB25DE engine and it is coupe and auto, it may be the GTS25, my main point is, does the vin plate says RB25DET if its turbo or does it just say RB25DE?
I am confused, I have all the paperwork, and the original owners 'National Warranty Company' booklet for victorians, as this car was bought in VIC and transferred through regency to SA, as i have the regency papers.
I just want to know if its a factory GTST or a GTS or GTS25 or what? different people are telling me, different things. if someone is able to email me privately i could send them the photos of the VIN and COMPLIANCE plates?
thanks
G'day mate could you check this vin it's meant to be a 1990 r32 gtr nismo gunmetal kh2 paint code
Vin: BNR32-100032
Model: KBNR32RXFSL RA
also if it's possible to find out If it had a/c and radio as I've been told that it was an option on the nismo
  On 14/08/2011 at 2:51 AM, mikeyR33-T said:
hi,
thanks
If it was originally a GTS4 (i.e it is 4wd) it would be ENR33. I tried them all this morning, and no combination would work.
F = CA18
H = RB20
E = RB25
B = RB26
C = Super HICAS
N = Atessa
R = Chassis
CHASSIS CODES
-ER -- GTS25
-HR -- GTS
-ECR -- GTS25t
-ENR -- GTS-4
-BCNR -- GTR
Yes, if it says ECR, it is a turbo chassis/engine. The brakes are different, the number of wheel studs are different... i'm sure there are many other differences. If you had a motor swap, and you have a DE (Dual overhead, EFI) then either the plate is wrong, or the motor was swapped out.
So... if your chassis was a turbo model you should have 5-stud wheels, a stronger gearbox (not sure how to tell, but it could be a manual-only thing), obviously you'd have no boost gauge in the dash. The side-mount intercooler would have plumbed through the engine bay via two holes infront of the air filter box. That should be very obvious.
Check those things? If the chassis has all non-turbo parts, I would *guess* there is something wrong with that plate. Strangely though, that plate doesn't belong to another chassis... it just doesn't exist. =-o
Let us know.
-Steve
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
    • Continental have consistently beaten the absolute shit out of every other performance tyre in Wet/Damp/Cold conditions and give up a little bit of time (half a second at most) in the dry. Almost like it's engineered for German conditions or something. I'd def give those a try.
