Diff =/= Final Drive.
Final drive ratios for All 32 GTST's manual or auto are the same as R33 Auto Ratio (4.3:1) Manual 33 GTST's run a 4:1:1 final drive ratio.
The differential bolts inside of the crownwheel(Parts of the final drive) and this gives you your LSD. When you buy a Nismo LSD kit you will not get a new final drive crown and pinion so your ratio will stay the same.
Well there ya go, cheers mate :thumbsup:
Hello!
Would greatly appreciate some help. I think this is the correct VIN. (hopefully)
The car is imported from Britain to Sweden. I don't know if that information is needed.
#WGNC34018235
Cheers guys!
Edited by Miltuun
Thanks for that! does this program do anything else? or just provide those details?
Can provide part numbers and Model Options. Miguelone can translate better than I can.
WGNC34129431 Please. Thank you very much in advance!
Wow! It's a regular Stag Fest lately. :D
Edited by Not a Pulsar
Hah yeah I saw another Stagea member post it in the stag section and he got directed to here so I thought, why not !
I had trouble with fast before as I run win764bit. Now have just found fast 2010 64bit compatible here - http://club-s12.org/retro4/index.php?topic=32213.0
download will be finished in 4 mins
Thanks for the quick response!
Nice one. Ima needing a more recent 32bit version. :(
I am not sure if I misunderstand you. Are you saying that it won't work for you ? It's 32 and 64bit compatible incase you thought it was only 64bit.
Sorry if I misunderstood. It's the sad smiley that has me all confused :D
More recent US version using older Jap files will be the same as using the older version though. Have a look around for the 2009 Jap version for the catalogues and use the current english version program. Works the best.
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
