May i have bnr32-017857 decoded?
Can't edit my post, i think the number is actually bnr32-047857, not 017857...
Both those numbers had complications.
Post a pic of you build plate and let us have a look.
Well that's the problem, it's not on my plate it's on the engine. I know my chassis is a 1993, i can still post a pic, but supposedly the stealership i bought it from here in Okinawa said it has a newer, but lower mileage engine in it, not the factory one (not sure what happened to it). So newer would mean to me 93+ model year engine. But i have reason to believe it's in fact NOT newer, so I'm a bit curious. I'll see if i can get better look at the numbers, had my wife look at it and she said it looks like the first number I posted, 017857. So i dunno.... :( Edited by Silverstreek
Well after further looking into both the VIN's you posted, they both came up as (July) 07 / 1991 models...
Wouldn't surprise me about the engine swap, it happens in Japan...
Still post a pic of the VIN's and lets have a look.
Also, do you have the VIN engraved on the firewall?
Yes i do and it matches the blue plate, so that's good. They informed me before and after I bought it, the info about the motor, so i knew it wasn't the original. But, like I said, they said it was "newer" AND "lower mileage". On the paperwork i got with the car it says "used engine ". So, I'm guessing if I tried to take it back and tell them i want my money back and to cram this car, I'd have no ground to stand on. Le sigh....
I see, thanks for that.
How many Km's has your GTR done (Speedo) VS the amount of Km's the "Used Engine" has done..?
Do you know if the timing belt has been changed?
Any stickers..?
Hi can someone please check, bnr32-309201
Thank you.
Kbnr32rxf7s aa
Thanks skyline.
Ok thanks!
The complications came up with a few results, one saying it was a Base Model and the other saying it's a V-Spec II.
But you Model Number confirms it to be a base model R32 GTR, built in March 1994.
Damn, can we go with the vspec II. :)
Thanks mate love you work.
I was checking cause I pulled motor out for rebuild and it has short nose crank so obviously not original motor.
:laugh:
It's just Brembo calipers that make the difference, along with a sticker and BBS Wheels for a V-Spec.
Not original engine or had the RB26 been modified from previous owner?
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
